Anyone have a stem with these dimensions or similar going spare perchance? 31.6mm clamp. Swapped the riser bars on my gravel bike for narrower ones - cured one problem, but caused another as they're now a bit low.
WTD: Stem - 90mm, 16deg or similar
- thenorthwind
Re: WTD: Stem - 90mm, 16deg or similar
ah i thought i had something but on looking mine is a silver X4 thompson 90mm X 31.8 with 0deg rise
I can lend one [ Hope if it matters and red] but i cannot sell as its on my SS but i dont ride it in summer
Useful if you are unable to get a better offer and want to check it will work
15deg x 80 any use to you Dave?
- thenorthwind
I reckon that's close enough. Will PM you
Thanks for the offer. I'll take you up on it if I don't find something permanent. Would look great on my red bike and match the red Hope hubs on the gravel wheels I use on it
Reckon that will be a bit stretched out, but cheers.
