Niche bars ... bamboo.
Although bamboo is technically a grass and not a wood, it is very strong. Strong enough to make bars it seems.
https://www.passchier.co.nz/product-cat ... andlebars/
Re: Niche bars ... bamboo.
bargain.......... ;o)
They are compared to Carbon loops
I 'spose they will sell loads being niche but I'd be slightly wary about longevity, especially given you will be clamping machined aluminium things to them with sharp edges etc....
I could imagine that they give a nice level of damping over rough ground, although foam grips would be a cheaper option.
I believe that is partly the thinking Rob.could imagine that they give a nice level of damping over rough ground
I like them and would like to try them, but i'm not 100% sure I would actually buy them...
I like the effort and skill put into making them too.
Si
Si
There's some coming for test / review. Very much looking forward to trying them and if they don't work as a bar, I'll add a string
Interesting...and open to lots of other uses, it could be cut up and made into a nice* wind chime or pan-pipe?
*not sure there is such a thing as a 'nice' one mind...
Are they compostable once they break?
Wonder if they can be used for additional water storage?
- macinblack
Surely of interest to this site's resident Panda handlers?
Do you use carbon bars? :)fatbikephil wrote: ↑Tue Feb 01, 2022 8:35 pm They are compared to Carbon loops
I'm told that if adding aero bars, then they supply a pair of 'clamping shims' but gps, lights, etc are no concern. Personally, I reckon I've more faith in bamboo than I have in carbon, after all I love their socksespecially given you will be clamping machined aluminium things to them with sharp edges etc....
Right enough and I suppose if they do snap its better to get a load of bamboo shards in your arms than carbon fibres and epoxy....jameso wrote: ↑Thu Feb 03, 2022 9:57 amDo you use carbon bars? :)fatbikephil wrote: ↑Tue Feb 01, 2022 8:35 pm They are compared to Carbon loops
As far as I know the passchier bamboo handlebar is made from bamboo, carbon and resin (eg epoxy). Carbon is used for the sleeve inside the bamboo in the stem clamping area.fatbikephil wrote: ↑Thu Feb 03, 2022 11:10 amRight enough and I suppose if they do snap its better to get a load of bamboo shards in your arms than carbon fibres and epoxy....jameso wrote: ↑Thu Feb 03, 2022 9:57 amDo you use carbon bars? :)fatbikephil wrote: ↑Tue Feb 01, 2022 8:35 pm They are compared to Carbon loops
