Exposure bar lights and Mr Jones
fatbikerbill
Post by fatbikerbill »
So what is the best way of mounting exposure bar lights to Jones bars?
Ideally I think I'd want to mount on the outer sweep but that is too narrow I think.
Mount on the back bar and the front casts a shadow.
Hang it upside down on the back bar then bar bags are in the way.
Re: Exposure bar lights and Mr Jones
Front loop is fine. Exposure mounts with the shims
lune ranger
Post by lune ranger »
benp1 wrote: Sun Jan 23, 2022 11:56 pm Front loop is fine. Exposure mounts with the shims
This.
It is however possible to mount a Revo (and other Exposure depending on size) to your fork crown (where this is possible) using a SON/ B&M/Supernova mount and an Exposure action camera adapter.
Your light can then sit under your bar roll on bikes with a tall enough head tube.
Wotsits
Post by Wotsits »
Dounle check to be sure, but i think its the 12 x 22.2 for the front loop. Just need to add something to stop it slipping..
https://www.ebay.co.uk/sch/i.html?_from ... 8&_sacat=0
Taylor
Post by Taylor »
A wrap of old inner tube for the northerners among us.
Blackhound
Post by Blackhound »
As Taylor says, old inner tube works just fine.
fatbikerbill
Thx all.
Now where did I put those shims.
I'll go digging.
I find inner tube too floppy for this use case.
If you can’t find shims try inner tube pulled really tight with a big wrap of half or third width duct tape
Self-amalgamating rubber tape is what you want.
Jurassic
Post by Jurassic »
I don't use Jones bars (I tried them and don't get on with them) but I do have Redshift Kitchen Sink bars on my gravel bike which throw up the same issue. I initially tried using various tape and diy packing options but found that the light would tend to move on bumpy terrain so I googled 22.2mm-31.8mm bar spacers and managed to get some dedicated widgets. These have worked well and the droopy light issue hasn't returned so I'd deem them a success. A quick search reveals these which look similar to the ones that I got. https://www.amazon.co.uk/dp/B077KS2RTZ/ ... WH7GWC4MQZ
u02sgb
Post by u02sgb »
I use the exposure mount that clips on with zip ties to the front loop. Works well.
https://www.exposure-use.com/Brands/Exp ... -Tie-Mount
L2R24
Post by L2R24 »
Exposure bracket fitted to a 3d printed mount from Raceware Direct.
