Apidura water bladder
Probably more for the racers, but a bit better looking than the plastic "fuel tank" looking frame water carrier, whadda we reckon?
https://www.apidura.com/shop/frame-pack ... 593ZruEIeg
Re: Apidura water bladder
I’m interested enough that I’ve ordered one. I’ve run a long narrow bladder in my half frame bag for long races (TDR etc) and really liked it. But the shape always irritates me. This, may work well at getting the centre of gravity of a lump of water down really low!
That does look interesting. I stopped using my full frame bag as it meant relocating the bottles.
I can get 2 x 500ml bottles in under my half frame bag. I think I could get 1.5L in that bladder AND more capacity above it in the rest of the full bag. I'll have to dig out the full bag and have a measure up.
This is what everyone has been waiting for. Should have been made available sooner than this, the only option that's similarish is the hard plastic standalone container
- thenorthwind
Can see a lot of sense in this. If I needed a new bladder, I'd be tempted. But I'm not sure I'd gain enough vs. a normal bladder stuffed in the bottom of my frame bag to make it worth it. Not an elegant solution, and perhaps not as stable, but still...
- UnderTheRadars
- Location: Stourbridge/North Col of North Worcestershire Alps
Good idea, but as I use my frame bag for heavy bits, tools, tent pegs and poles etc I’d be worried about puncturing it.
Agreed. Amazing breakthrough. Wish it came in 2L flavours. My 3L I usually fill up to 2.5L so this should/might do me a good job (as long as that tube is long enough.
Thanks Scud
Thanks Scud
One thing, i guess it places the weight of the water at the best place, middle and low, on the bike too, more i think about it, actually it is no just for the racers..
I really like that but shouldn't the hose be fitted at the very bottom?
- Dave Barter
Great design especially the removable hose. I'd prevent punctures with a layer of Baby Bels
You can get an adapter from Camelbak to make any hose removable - quite useful.Dave Barter wrote: ↑Tue Jul 27, 2021 3:46 pm Great design especially the removable hose. I'd prevent punctures with a layer of Baby Bels
Is it really though? Is it not simply a better fitting bladder? Most of us will still need to unpack / repack our frame bags in order to fill it unless we purchase a specific frame bag.Amazing breakthrough
I bet there's an Apidura one it fits perfectly.Bearbonesnorm wrote: ↑Tue Jul 27, 2021 4:23 pmIs it really though? Is it not simply a better fitting bladder? Most of us will still need to unpack / repack our frame bags in order to fill it unless we purchase a specific frame bag.Amazing breakthrough
It would certainly be a struggle getting it into my Lomo frame bag, even when empty. Some way of using the hose to fill it up in situ might help.
Should slot straight into any of the older Revelate bags that have double straps. Or the Spearfish Wildcat one I have, which is the plan.Bearbonesnorm wrote: ↑Tue Jul 27, 2021 4:23 pm Is it really though? Is it not simply a better fitting bladder? Most of us will still need to unpack / repack our frame bags in order to fill it unless we purchase a specific frame bag.
From Apidura via bikepacking.com
The hose connection location has been chosen for optimum flow rate (it reduces the risk of kinking). The bladder is soft, so compresses as it empties and all of our testers were able to empty the bladder by suction alone with this layout. Our extensive testing showed that gravity is less of an issue than flow rate, as long as the bladder is compressible.
https://bikepacking.com/news/apidura-fr ... n-bladder/
Surprised no-one has uttered the Barnsley war cry. HOW MUCH!
Meaning all the other items in your frame bag then start to rattle aboutThe bladder is soft, so compresses as it empties
Yep, I'm sure they'll fit inside many frame bags Greg but my point was more about needing to unpack / repack to fill it ... I appreciate just how much will depend on the frame bag in question.Should slot straight into any of the older Revelate bags that have double straps. Or the Spearfish Wildcat one I have, which is the plan.
Would a frame bag with a completely and easy to access separate bladder compartment not be a better design?Great design especially the removable hose.
I know I sound like I'm knocking it but it's just that it's a triangular bladder, Shaf calling it a 'breakthrough' kinda made it sound like world peace was on the way
It would work in my wildcat bag with a horizontal divider but in a big single compartment bag as you drink; stuff in the bag will sink. Guess it depends on what you carry in yr frame bag. I use a normal bladder in the front compartment of my other wildcat bag and it works fine.
- Dave Barter
When stu rates a new product I am hot footing it to London to ring the Lutine Bell
Someone ought to invent a bike frame that makes use of all that wasted space inside the tubes. Think how much water you could fit inside a nice chunky alu frame
Cleaning it out might be an issue though, I suppose. Drop a Milton tablet down the seat tube once every few months and shake.
I recall Moots did that.Someone ought to invent a bike frame that makes use of all that wasted space inside the tubes. Think how much water you could fit inside a nice chunky alu frame
There really is nothing left to invent.Bearbonesnorm wrote: ↑Tue Jul 27, 2021 9:06 pmI recall Moots did that.Someone ought to invent a bike frame that makes use of all that wasted space inside the tubes. Think how much water you could fit inside a nice chunky alu frame
https://www.cyclingabout.com/moots-snoots-fat-bike/
What’s special about the Snoots is that it has liquid storage INSIDE the frame tubes. Fuel, water, whisky – you name it. The inputs are located at the highest possible point, and small taps are found at the lowest.
- JohnClimber
How did I not spot that, job for work tomorrow to print one of them.JohnClimber wrote: ↑Tue Jul 27, 2021 9:57 pm I like how they give you a template to cut out and try against your frame bag before you press buy
- JohnClimber
Mine arrived today and I must say it's bloody brilliant.
If you over fill it a little the velco is tricky to stick down, but once the 4ft of pipe is in place (about a foot longer than is needed at the bars) and you've sucked the air and the extra water out if it and once it's in place in the bottom of the frame bag (space under mine for a tool and CO2 cylinders) it's brilliant.
It's amazing how much space that you get above it where the top of a normal round opening of an oval shaped camel back bladder would be clogging up the top of the frame bag.
Well worth trying out.
