Another "one for the coffee snobs / enthusiasts / weirdos"
I saw this and thought of *you*:
https://www.celsiusbrewing.com/products ... E3X5OWGDnI
Possibly not quite compact enough for the average bear :wink:
Re: Another "one for the coffee snobs / enthusiasts / weirdos"
The important question, will it fit inside a Myti mug 650?
65mm dia and 75mm high, it looks like it would fit in my msr mug which is only 400ml. The fold down arms help with the packing. Not sure I can justify another coffee device.
Saying that, when I got my Aeropress Go the wife thought it would be a novelty and I'd soon get bored of the 'hassle' but I've just finished the box of filters that came with it so I've made 350 cups of coffee with it in just under a year.
I've got one of those ^^ at home.
It's not great, as it sits too deep in the cup, and once the point of the cone is below the level of the liquid in the cup, it stops dripping through.
Looks like bugger to clean! Double layer filter => traps what gets through the first filter between the two, surely?
Moff
Post by Moff »
This thing is brilliantly ridiculous
https://briping.com/
I want one!!
RobLyon
Post by RobLyon »
I just use the aeropess at home and I keep re-using the filters
I'll see your ridiculous and raise you ...
The Barista9, a snip at £295 :shock: Yes you read that right, £295
Mr conners
Post by Mr conners »
RobLyon wrote: Wed Mar 24, 2021 7:29 pm I just use the aeropess at home and I keep re-using the filters
You can get reusable metal ones off eBay. I’ve had mine about three years.
BigdummySteve
Post by BigdummySteve »
whitestone wrote: Wed Mar 24, 2021 9:47 pm I'll see your ridiculous and raise you ...
To be fair it’s actually quite clever with its pressure and thermal management, definitely not your average moka pot. Apparently it makes good Proper espresso.
I have the nylon (?) mesh filter and molded frame from a £15 aldi coffee perculator. Weigh less than 20g. Sorted
At 6:00 min https://youtu.be/LFNtuIQV1U0
Aldi ambiano coffee maker
Not this! https://www.aldi.co.uk/ambiano-espress ... 5466092701
