I’m selling a medium 2018 Scott Spark 920. It’s all stock other than the brakes and an upgraded Bontrager carbon handlebar. I’m 5’10 and it’s just right. Possibly the most versatile and fun XC race bike available!
Over the last year the bike has done less than 500km due to injury and a new arrival at home. The following maintenance has been done:
• Headset bearings replaced (Dec 20)
• All inner cables replaced (Nov 20)
• Chain & cassette replaced (X01 chain and GX cassette, Oct 20)
• Shock & Fork serviced by TF Tuned (July 20)
It’s been really well looked after - there are some scratches, as to be expected, but I’ve tried to highlight them in the photos. I used a different wheelset with the bike so the wheel bearings are in good shape. Will also include the Syncros Fox 34 mudguard. The brakes have been replaced with brand new Shimano M4100 caliper and levers.
Overall it’s an excellent bike, fast climber and amazing fun on the descents – it’s just not getting enough use and I can’t justify having it around anymore not getting ridden. Any questions please do give me a shout.
I’m happy to post but price does not include postage - contactless viewings can be arranged too.
Spec is as follows:
Frame Material - Carbon Fiber
Frame Material Details - HMF Mainframe, alloy SL 6011 swingarm with internal cable routing
Rear Shock – 120mm FOX NUDE DPS EVOL, Scott custom tune, Trunnion, 165mm x 45mm, lockout, TwinLoc Suspension System
Fork – 120mm FOX 34 Float Performance Air, GRIP3 damper, Boost, lockout, TwinLoc Suspension System
Head Tube Diameter -Tapered, 1.5" - 1 1/8"
Headset - Syncros Pro Drop In
Handlebar – Bontrager Rhythm Pro, OCLV Carbon, 31.8mm, 15mm rise
Stem - Syncros FL2.0, alloy 6061, integrated spacer and top cup, 6° angle, 31.8mm clamp
Grips – ODI F1 Float but will include original Syncros Pro Lock-on grips
Brakes - Shimano M4100 with 180mm front/160mm rear Shimano SM-RT64 CL rotors
Shifter - SRAM GX Eagle, 12-speed
Rear Derailleur - SRAM GX Eagle
Chainguide - Integrated
Cranks - SRAM X1 1000 Eagle, Boost
Chainrings -32 tooth
Bottom Bracket - SRAM GXP, press fit, integrated, shell 41mm x 92mm
Pedals - Not incuded
Chain - SRAM X01
Cassette - SRAM GX XG-1275, 10-50 tooth, 12-speed
Rims - Syncros XR2.5 CL, 25mm width, tubeless ready, 28 hole
Hubs - Syncros XR2.5 CL, Boost front and rear
Tires - Bontrager XR3, 2.4 (front) & 2.3 (rear)
Saddle - Syncros XR2.0, chromoly rails
Seatpost - FOX Transfer Dropper 125mm drop
Seatpost Diameter - 31.6mm
Seatpost Clamp - Standard single bolt
Rear Dropout / Hub Dimensions - Boost, 12mm x 148mm
Weight 12.8kg
Looking for £2000. More pics available - thanks for looking
FS: 2018 Scott Spark 920 Medium
Re: FS: 2018 Scott Spark 920 Medium
Hi
Can’t find the price in the advert ?
Also can I ask what’s your inside leg measurement? ( im trying to gauge if the size fits)
Whoops! Cheers, updated, but I'm looking for £2000.
I'm 32" inside leg.
I'm 32" inside leg.
