WTD: Centrelock rotors 160 + 200mm
Johnhenry
Post by Johnhenry »
Has anyone got a 160mm and 200mm centre lock rotor ?
I've got plenty of rotor's but all 6 bolt so can swap if it helps......
Teetosugars
Re: WTD: Centrelock rotors 160 + 200mm
Post by Teetosugars »
Pretty sure I've got some adapters for 6 bolt to center lock if you want them?
I have some 160s maybe 180s
Will check in the basement tomorrow for you.
