Handlebar Harness
Handlebar Harness
Another lockdown project while my bung knee heals.
Inspired by ( ripped off) Wildcat Lion and Cactus Love Handle
Front harness https://imgur.com/gallery/2SvggZK
Front harness https://imgur.com/gallery/NmnZWRI
Front harness https://imgur.com/gallery/PMbZyp9
Re: Handlebar Harness
Long press the actual pic and then just click URL (in left od my pic). You'll get a message saying 'copied'
Now click on the 'image' icon which I've circled. It'll give you some brackets like this [......] [.......]
Long press between these two brackets. Your copied thing from the IMGUR will show up as wanting to be pasted. Make sure you paste it precisely between both sets of brackets... if you find it hard to hit the spot, then jusy create some 'spacebar' spaces between the 2 sets of brackets first. This will create some space so your fat fingers (assuming they're fat) can grt in between em...
Voila...
- thenorthwind
That looks very nicely made
Thanks for heads up posting pics.
I'm pretty pleased with the harness though it hasn't been used in anger yet. Came out a bit heavier than planned at around 360g.
All materials ( VX21 "coyote", polyester webbing, spacer mesh lining, etc) from Profabrics.co.uk
'G' hooks I already had.
Stiffener to upper half is a flexy chopping board from Argos ( pack of 4 =£5.00)
Nice work, I assume you made the rest of your luggage as it matches.
How do you find the G hooks? Do they stay tight, and how easy is it to pull the free end to tighten them up?
Also, what bars are they?
Thanks. Yes I made the other bags. There are more pics on my imgur page.
The G hooks work really well. I've done thousands of miles with them on the bar bag I made without issue. They tighten up and loosen fine. They're steel so a little heavy but no heavier than a plastic side release bukle. Extreme Textil never seemed to have alloy ones in stock when I've ordered other stuff.
The bars are Gusset Stache. Cheap , light and comfortable.
https://www.gussetcomponents.com/shop/s ... tash-bars/
I bought them through Triton Cycles
https://www.tritoncycles.co.uk/componen ... bar-p13460
- TheBrownDog
Really good work. I have tried many times to make a few simple bits of luggage and they have all been dreadful.
I am however intrigued by Shaf's attempted thread highjack ....
Shaf’s hijacks are just proof that if you go off enough tangents you will eventually get back to the point, a bit like a conversational dodecahedron
TheBrownDog wrote: ↑Tue Oct 20, 2020 5:56 pm Really good work. I have tried many times to make a few simple bits of luggage and they have all been dreadful.
I thought I just did the greatest community service the forum has seen this week. I first noticed Woodsmiths attempt in the 'How to post pics' thread with a test pic. Then noticed he'd not managed to put the picture on this thread. I recalled how Colin and some other folk had helped me when I finally managed to post a pic after 2 years...
The rest as they say is history Hope everyone likes Joes MSR pegs (they really must be)...
Hi Woodsmith
Nice work, well done.
I’ve been using a Wildcat bar harness, and sometimes it does its job (not catching the front mudguard when the suspension dips), and other times it does NOT, and I can’t quite fathom what causes it to drop.
I’ve studied the way the straps are, underneath the front arch of the fork, back again to thread through, then over the handlebars to thread into the buckle in the harness.
I’m thinking there may well be some better design to keep the harness higher and well clear when the suspension dips.
Does your bag have the same fastening design as the Wildcat ?
And I notice that you don’t have front suspension.
Would your bag work with suspension ? I.e. not dipping to catch the front wheel.
I’ve been recently using an old BP (Bikepack Poland), and the two straps simply loop around the handlebar then back into a buckle with a ‘lid’ that locks it in place.
And it works !
And it works !
I Think that mine is slightly different to the Wildcat Lion in that I omitted the strap which loops over the handlebar.ericrobo wrote: ↑Thu Oct 22, 2020 11:59 am Hi Woodsmith
And it works !
https://wildcat.cc/pages/wildcat-lion-instructions
I just have the strap which is fixed to the upper part of the harness, loops over the handlebars and ends in a ladderlock.
And a second strap fixed to about 3/4 of the way down the rear part of the harness which loops under the fork through a triglide and is tensioned in the ladderlock on the upper part.
I also added a loop to ( hidden by the foam block) to run a strap around the headtube. I dont think this is featured on thr Wildcat.
I have'nt used it in anger yet but bouncing the front end and riding up and down the kerb outside the house it seems to be rock solid. If it does begin to slip or need constant retightening I could add a couple of cam locks to trap the loose end of the tensioning strap.
as to whether it would work with a suspension fork, I've no idea but i can't see why it shouldn't.
I may be misunderstanding your description, as it doesn't sound like the way that I set up my Lion.ericrobo wrote: ↑Thu Oct 22, 2020 11:59 am .
Here is the online description, directly from wildcat
The wilcat appears in the drawing ( I've never seen one in the flesh) to have two straps over the handlebar: one leading to the top edge of the harness and the other going down . I omitted the one which goes down.belugabob wrote: ↑Wed Oct 28, 2020 3:10 pmI may be misunderstanding your description, as it doesn't sound like the way that I set up my Lion.ericrobo wrote: ↑Thu Oct 22, 2020 11:59 am .
There is only one strap, in effect (well, on on the left and one on the right)
It goes over the bar, attaches to the harness, runs down the harness and continues through a buckle, under the fork crown, back up through the buckle and through the ladder lock at the start of the strap
