Lanshan 1 users what length pole are you using
Just picked one up from ebay , more than I wanted to pay but hey ho it's the older inner and outer that I wanted
So what length pole are people using as there seems to be a mix of answers on the net, I'm thinking 49 inch (125cm) like the lunar solo
Re: Lanshan 1 users what length pole are you using
There's a sweet spot but I forget exactly what it is - sorry. However, 125cm will work fine.
- Bearlegged
Having just bought Al's old one, he told me that 120cm is ok, but 125cm is better.
Merci, stu I shall be messaging you shortly
Just bought the ‘pro’ version which is a straight rip off of the lunar solo . First night in it this evening (and very nice it is too...).
I’m using the 120mm pole from a trailstar set with a 6cm extender stu made. 120 does work, but the pitch never looked quite right.
126cm is spot on I reckon
- TheBrownDog
I used a 120cm pole on my first night in mine but the inner mesh was annoyingly close to my face. A 10cm pole extender (thanks again Stu) raised it up nicely. So 130cm for me.
- TheBrownDog
Cheers I shall have a play with my adjustable pole from the mini peak and see what works best rather than rushing for a new one straight away cheers all
I had a quick play in the garden today until the rain came, unfortunately the grass was soft the pegs pulled out it was windy and the pole sank doh.. oh and my grass is on a slope. Will try again when I get chance before I order a carbon pole, 130 seemed too long though will have a play again ta
Worth bearing in mind that every Lanshan may not be exactly the same.
Ah yes I didn't think of that its very possible:)
These are the answer to that issue
https://bearbonesbikepacking.co.uk/shop ... -pole-feet
Handily available from the same shop you'll be ordering your pole from
I have noted those thanks but alas I need to stop it first haha
firestarter wrote: ↑Tue Jul 07, 2020 8:05 am I have noted those thanks but alas I need to stop it first haha
Mick, does this mean your other set up is for sale mate???
Lol I hadn't thought of that tbh but that is an option perhaps I will set them both up when its sunny next week and have a think mate
So I have a Lanshan 1 Pro inbound. Do I just buy the SMD Lunar Solo – carbon, single Pole-A-Bear, or am I going to have to chop up a broom handle to find the exact length for this particular tent and buy a custom length...?
just ask him for a pole for that tent and he will know what size is required
I tend to use the pic n mix poles from Stu not had any trouble as yet
Iirc the one i got made was 127cm as it kinda has a particular sweet spot , mine wasn't the pro though just the older one so may be of no help
126cm stu pole with the lanshan 1 and now using the same with the pro.
I have a lanshan pro 1
I'm using the bear bones pole for the lunar solo.
125 I think.
Works well.
125 I think.
Works well.
Grubby little urchin.
