[WTD] Blutos? 150mm Fat Bike Forks
- Escape Goat
Hey
Has anyone got a set of fat forks knocking around? 150mm spacing. I'd really ĺike blutos
Also fat cranks for OOF.
Re: [WTD] 150mm Fat Bike Forks + Fat Bike Cranks
I have the forks off my old medium Calibre Dune, I also have the thru-axle. there are a few areas of cable rub, and some scuff marks, I can send more photos. The steerer is 17.5 cm in length, which is how it was supplied:
Plus I have the Lasco cranks, fitted with a 34 tooth Absolute Black oval narrow-wide chainring:
- Escape Goat
Hey. Really interested in the cranks please.
- 99percentchimp
Some here too - will have a look in the box of bits too if you still want options.
Conquistador of the pointless
- Escape Goat
Yeah let me know as well please :)
- 99percentchimp
Surly OD Cranks 175mm and 2x (36/22T) - almost as new - have a front mech and shift too?
Surly OD Cranks 175mm 2x by 99percentchimp, on Flickr
Forks are maybe not what you after - 9szero7 black but 135mm spacing... about 200mm steerer?
- Escape Goat
I may have a little look at some Sram chainsets (wouldn't mind being able to swap out rings between bikes as I use oval :)
- Escape Goat
Re: [WTD] Blutos? 150mm Fat Bike Forks + Fat Bike Cranks
Still looking. Will consider 150mm carbon too. Non Chinese though.
Is 142mm carbon forks any use or does it have to be 150mm?
Got a salsa makwa fork somewhere but that falls goal of your anti China vibe as salsa stuff is manufactured in Taiwan.
- Escape Goat
Oooh I mean non branded / tested etc.
It does have to be 150mm :( but interested in the salsas.
The salsa one I have is from a 2015 beargrease framset which is 142mm FDS.
- Escape Goat
Ah thought I was onto a winner.
I can find Salsa Barepaw and Whiskey no9 forks at 150mm carbon but nothing else. Almost found some salsa forks for 449 but they're alloy! How come so much?!
Hi i have soon Blutos 150mm 120mm travel in the garage which i can sell will if you are still looking for some?
