Bar end shifters
techno
Bar end shifters
Post by techno »
I've got some drops and Dura ace bar end shifters on the way so I can try monstercrossing my stooge. it's first time I will have set up any sort of drops so What's the consensus on the best way to route gear cables for bar end shifters?
Ta.
PaulE
Re: Bar end shifter cables
Post by PaulE »
I've run them with the inners all the way up the bar to by the stem, and also coming out of the tape in the drops a bit below the lever clamp. The first way looks cleaner, and is less likely to catch on fingers but the second gives smoother routing and shifting (and is a bit lighter if that bothers you)
Mine are all routed beneath the bar (below the tape) and exit where the tape ends on the tops.
My fargo came with the cables coming out of the tape on the drops. When I retaped/cabled I routed them out by the stem and it had no adverse effect on shifting. It made it a lot easier to fit luggage in the bars and looks neater to boot.
techno
Post by techno »
thanks all, i'll try routed to the end of the tape first and see how the shifting is :-bd
BigdummySteve
Post by BigdummySteve »
My brake hoses are routed on the underside of the drops. When I’m holding the tops they sit underneath my fingertips, it’s not uncomfortable but I’m aware of them. I might try routing them at the back of the tops next time. I’d try a few different positions with electrical tape and see where you find it most comfortable.
techno
Post by techno »
BigdummySteve wrote: Mon May 11, 2020 1:50 pm My brake hoses are routed on the underside of the drops. When I’m holding the tops they sit underneath my fingertips, it’s not uncomfortable but I’m aware of them. I might try routing them at the back of the tops next time. I’d try a few different positions with electrical tape and see where you find it most comfortable.
yeah that sounds like a plan. good idea.
middleagedmadness
Post by middleagedmadness »
Mine are routed the same as the sti’s were, once the bars are double wrapped you can’t feel them
techno
Re: Bar end shifters
Post by techno »
Right, bugger. I think I've dropped a Clanger.
So, I've got these Dura ace bar end shifters (like these https://www.somafabshop.com/shop/produc ... -used-5255 )
on the way. But my rear mech (I'm running 1x10) is a deore clutch jobby (this: https://www.bikeinn.com/bike/shimano-de ... 36627490/p )
They're not going to work together are they?
Or will the Dura ace in friction mode be ok?
Fingers crossed!!!
windjammer
Post by windjammer »
i routed all my cables to exit at the rear of the bars to make it easier to mount the bar harness,when i fit cables now to any bike i all ways fit the bag harness first then route the cables accordinly
windjammer
techno wrote: Tue May 12, 2020 11:16 pm Right, bugger. I think I've dropped a Clanger.
Fingers crossed!!!
you could use a wolf tooth tanpan or clamp the caple to a different side of the mech to alter the pull ratio
chris n
Post by chris n »
Fingers crossed!!!
Microshift make a bar end shifter (BS-M10) that is compatible with Shimano MTB 10-speed.
techno
Post by techno »
windjammer wrote: Wed May 13, 2020 8:29 am you could use a wolf tooth tanpan or clamp the caple to a different side of the mech to alter the pull ratio
Thanks forgot about that. Had a look around and for £20 less: https://www.sjscycles.co.uk/cables/jtek-shiftmate-6/
Do you mean putting the clamp bolt through from the bottom?
Or leave the bolt where it is and clamping the cable at the other side to the guide slot?
windjammer wrote: Wed May 13, 2020 8:27 am i routed all my cables to exit at the rear of the bars to make it easier to mount the bar harness,when i fit cables now to any bike i all ways fit the bag harness first then route the cables accordinly
Good point, i'll try my revelate harness on there before I tape it all up.
techno
Post by techno »
chris n wrote: Wed May 13, 2020 9:44 am Microshift make a bar end shifter (BS-M10) that is compatible with Shimano MTB 10-speed.
Thanks, I'll price up the different options and see what's cheapest.
techno
Post by techno »
Maybe I'll just make it single speed.....
techno wrote: Wed May 13, 2020 10:51 am Maybe I'll just make it single speed.....
That's the most sensible thing that's ever been said on here :grin:
techno
Post by techno »
sean_iow wrote: Wed May 13, 2020 5:32 pm
:lol:
You'll need a 9s non-clutch MTB mech to run 10s index road shifters. But you may be suprised how well modern narrow chains and ramped cassettes work with friction shifters, far less adjustment post-shift needed than I expected. I use a mix of 9 and 10s on my MTB 'packer to get a clutch mech on old 9s kit and you just get a feel for how much to move the thumbie, it's no problem. Worth a try (as is SS :grin: )
techno
Post by techno »
jameso wrote: Thu May 14, 2020 10:33 am
Thanks James,
I was intending to try friction mode first if it will work, so that's what i needed to hear :-bd
It'll be nostalgic, going back to the days of:
EDIT::
check these i spotted when searching for that pic:
https://www.bikeradar.com/features/thro ... lideshow=1
http://www.vintagemtbworkshop.com/1987- ... ature.html
on the theme: http://www.kellybike.com/product/takeoff/
techno
Post by techno »
Update:
I'm still waiting for the shifters to come but couldn't wait to fit the bars! Not been for a ride yet and have a few different stems to try tuning the position so the set-up will no doubt change but I'm happy so far!
Also got some skinny CX tyres for my 29er wheels for when I feel like pretending to be a roadie :lol:
(160.02 KiB) Downloaded 631 times
