TDR bike suitability
- AndyTheBikeGuy
Hi all, looking for some advice from those who’ve ridden or raced the Tour Divide.
I’ve got a Sonder Signal Ti and I’m looking to replace my Rose Cross Bike for gravel and road riding and I’ve test ridden Sonder Camino Ti and I’m really sold on it for my needs.
However I have an aspiration to enter the TDR in a couple of years time and I’m speculating which (with a bit of component alterations) would be the more suited bike for the race?
Would a signal with a rigid fork and something like 29er Ikons or Mezcals be better or a Camino with some 27.5x2” tires be better?
I’m aware better is subjective so maybe it’s what would you rather ride?
I had looked at a custom Ti frame more like a Cutthroat from Sonder but I think it would be more compromised for my daily needs just to make it suitable for the TDR.
Cheers, Andy
Cheers, Andy
Re: TDR bike suitability
Can't answer your main question, but have you considered the Smokestone Mr Harry...?AndyTheBikeGuy wrote: ↑Mon May 04, 2020 11:43 am I had looked at a custom Ti frame more like a Cutthroat from Sonder but I think it would be more compromised for my daily needs just to make it suitable for the TDR.
I'd go for the signal over the camino if I had to flip a coin.
Though we rode broken roads with 29er ikons. I'd certainly not ride a rigid bike, my hands were numb for months after the TD and that's with 100mm of travel up front.
Blog - thecyclerider.com
- NewRetroTom
I'd go for the Signal.
I did ride a rigid bike and like Rich my hands were numb for months.
- AndyTheBikeGuy
Thanks all,
I looked at the Smokestone but it’s probably a little out of my price range and I think it would be a little compromised on the road.
Thanks for the advice on the Signal, sounds like it’s the best option. I would have gone for a Broken Road in the first place but I really enjoy the lairyness of the Signal for Lakeland descents after back to back test rides.
Sounds like you need Mr Barter's input as he's done the TDR recently. If you haven't, search the forum (possibly in trip reports) and he put quite a write up and film of it. He's always entertaining and informative, in a very blunt, personal, adult kinda way
Gregg May has done it as well.
There are probably plenty of others, just the two I can remember off top of my head.
I used a Ti 29er with Carbon forks. Not sure that suspension would really have helped as I think most of the hand and arse grief comes from hours in saddle and constant knocks rather than big impacts.
I've not ridden a signal but I'd certainly take a 29er with big XC tyres over a Camino.
I went for the Ti frame for it's legendary zing and if I'm honest my carbon Lurcher was more compliant. Having just picked up a Cutthroat I'm tending towards the Ti zing and spring to be apocryphal really.
- Dave Barter
This.johnnystorm wrote: ↑Mon May 04, 2020 12:28 pm I used a Ti 29er with Carbon forks. Not sure that suspension would really have helped as I think most of the hand and arse grief comes from hours in saddle and constant knocks rather than big impacts.
I used to get terrible numbness with my Ti 29'r and flat bars. The Cowchippers on my Cutthroat made a massive difference. I never once thought suspension forks would help. But this is bikes ain't it. So everyone will be different. My view is the TD is more about coping strategies and less about kit. I'd invest in those.
- AndyTheBikeGuy
Thanks all that’s all great info. I think once it’s all safe to do so, just riding longer and back to back on my Signal will give me a good feeling for it.
I’ll put my time and money into coping strategies, are the R@pha ones the best or should I just look in Aldi?
Crikey, how much Brevet shorts are worth every penny.AndyTheBikeGuy wrote: ↑Mon May 04, 2020 1:56 pm Thanks all that’s all great info. I think once it’s all safe to do so, just riding longer and back to back on my Signal will give me a good feeling for it.
Oh, I see Ràpha gets changed to a misspelled "crikey".johnnystorm wrote: ↑Mon May 04, 2020 2:00 pmCriky, how much Brevet shorts are worth every penny.AndyTheBikeGuy wrote: ↑Mon May 04, 2020 1:56 pm Thanks all that’s all great info. I think once it’s all safe to do so, just riding longer and back to back on my Signal will give me a good feeling for it.
Double post
I used a Jones with 2.35 Ikon's. No hand problems at all on a rigid bike. Bear in mind the Divide is a very long, mostly gravel ride, with some horrendous washboard. Only a small amount of people race it, several hundred people a year potter along it on a variety of machinery, gravel, mountain, CX, use whatever you fancy.
Comfort is key. My opinion is to do as many road miles on the bike as you can. On the road you tend to stay in the same position for long periods which shows up any discomforts. This is what you'll be doing on the Divide.
I had planned on using my rigid Stumpy. I can ride it off road all day, 50 miles on the road and I need a couple of days to let my hands recover.
You want big tyres - fast rolling and fairly tough 2.3 or 2.4s. Comfy riding position. Drops or whatever alt bars you like, just expect that by day 8 anything you thought would be comfy will need to be higher/shorter/more padded. Don't fall into the trap of thinking it's a gravel bike thing, if you're racing it's more about the likely gradual collapse you'll be experiencing toward the end and planning for whatever will get you through that. A gravel bike will just kick start your collapse a lot sooner
Done deal then. There's some flat out fun open descents on the route and anything that puts a smile on your face each day will make the tougher aspects a lot more bearable. Amazing how much of a lift a good descent buzz can be.I really enjoy the lairyness of the Signal for Lakeland descents after back to back test rides.
- AndyTheBikeGuy
Thanks all, those are a couple of things I hadn't thought of. It's unlikely to be in the next couple of years, but something to aim for.
Just imho/fwiw.. just do it .. things change and the further ahead you put it the less likely it'll be or potentially the less fire you'll have for it by then? You could be top 20% competitive next year if you can do a few longer days back to back now and have the self-supported ability already.
Disclaimer - I’ve not ridden the route, not even a single part of it - However -
If you’re looking at a hardtail, then the Trek Procaliber is well worth looking at, the rear ended is really comfortable (I was sceptical of it but am amazed how good it is!)
Oh yeah, in my excitement to upset folk, I missed the 'e' outOh, I see Ràpha gets changed to a misspelled "crikey".
- JohnClimber
Still dreaming of doing the TD, so no expert
What ever bike you get it's worth considering one of these as the first upgrade I'd say
I've only had one very long ride on this new model ST version since it arrived last Fridayand it's amazing at busting the thuds.
I've had the original one for several months now which is great but it does wallow a little more than the new one.
I got both from Shona (from these parts) posted out from her shop Keep Peddling in Manchester
- In Reverse
Have you tried using Laufs for multi-day rides Rich?
- JohnClimber
mmmh Lauf's ;-)
and the new ST Thud Buster, Rohloff, Brooks C17 Cambium on my 29er+ Travers titanium
I need to do the TD, I so need to do the TD
I’m sorry but those forks are gopping, and they’re on backwards too.
I did it last year and had suspension forks, no numb hands, I have the urge to do it again and next time carbon forks and 650b plus tyres, I can highly recommend a carbon seatpost and a leather Brooks saddle, I met quite a few people with saddle sores and they where miserable.
Personally I would not dream of doing it on a 2 inch tyre if would be torture, other opinions also available.
I know have a Broken road with carbon wheels,Prong forks and the same carbon seatpost and saddle it is super comfy, almost everyone has aerobars and they helped me and I used them all the time.
TD might be the one place ever, maybe, where I'd use a Lauf fork. Maybe. : ) More reliable than a telescopic and should be better at the small fast vibrations. Washboard had me howling and swearing out load while riding. Hit a section at speed downhill unprepared, with sore feet and hands, and F*&%ing %$*&ard F*&% .. Always annoying, sometimes genuinely eye-rattlingly horrible.
I see Rene Herse (Compass Tyres new name) just launched a new 'designed for the TDR + AMR' / bikepacking specific tyre. It's a 2.2"
(I know the TDR was won on 2.1 Nanos for many years but that was before there was much choice?)
- AndyTheBikeGuy
Thanks hive mind. I feel a lot better about riding the Signal. Maybe a lauf, thundbuster and some Jones bars will do the job...
... and some Räpha shorts obvs...
