SPEARFISH Carbon medium
2017 CUSTOM BUILD
ROCKSHOCK SID FORKS 100MM WITH REMOTE LOCKOUT
FOX FLOAT REAR SHOCK WITH LOCKOUT TRAIL AND DESCEND MODE
SRAM 12 SPEED GX
HOPE M4 RACE
EASTON EA90XC WITH BONTRAGER SE 3 TEAM ISSUE
THOMSON CARBON BARS
THOMSON STEM
HOPE CARBON SEAT POST
WTB SEAT ROCKET
THERE IS A SMALL CHIP ON THE DOWN TUBE PLEASE LOOK AT PHOTOS
£1400
SURLY Wednesday medium
Surly says...... The Wednesday is the result of over a decade of fat bike design experience distilled into one steely-eyed package. With Wednesday, we borrowed elements from some of our Trail and Touring models to create a whip that can truly handle anything you want to attempt. Want to point it down the side of mountain? Go ahead, roll those dice. And if you make it to the bottom, you’ll be able to ride back to the top for round two. Wednesday’s geometry is spry enough to get you through techy stuff, stable enough for the fast stuff, and doesn’t feel sluggish on terrain-crawling stuff.
While Wednesday is plenty confident on terrifying terrain, it also has the chops for any sort of expedition you may want to undertake. We gave it all the necessary braze-ons and mounts for whatever accoutrements you feel necessary in your travels. Racks? Front and rear, friend. Fenders? You got it. Bottle mounts? How does triple bottle bosses on both fork legs and the down tube, and two sets of standard mounts on the main triangle grab you? We even gave Wednesday internal routing for a dropper post and Surly Trip Guides to keep everything nice and neat and free of rat’s nests. In the dropout department, Wednesday uses a cast steel, rear-facing, slotted dropout that can exit either rearward or vertically. They’re compatible with either 10mm or 12mm axles and are spaced at 170/177mm.
We wanted Wednesday to offer a lot of options when it comes to tyre clearance. In the full-forward, short chainstay position you can run 26 x 3.8˝ tyres on 80mm rims and in the full-rearward, longer chainstay position you get the option of 26 x 4.6˝ tires on an 80mm rim. Wednesday is constructed using our proprietary ED-coated 4130 CroMoly steel. ED coating is a process that provides a solid foundation for paint externally while adding a layer of corrosion protection internally.
Specifications:
• Frame: 100% Surly 4130 CroMoly steel
• Fork: Tapered straight blade 4130 CroMoly.
• Headset: hope
• Handlebar: 31.8mm Sam hill
• Stem: 4-bolt 31.8mm
• Saddle: WTB
• Sram x5 crank
• Front Derailleur: Sram X5
• Rear Derailleur: Shimano Deore
• Gear Levers: Shimano Deore
• Bottom Bracket: hope
• Brake Levers: Shimano XT
• Brakes Hayes: Shimano XT
• Rims: DT Swiss BR710
• Hope hubs
£900
Wheelset hope fatso 150mm 170mm sun ringle mule fut 50mm maxixis chronicle 29x 3
£300
• Frame: TREK PILOT 1.2 ROAD BIKE 58CM
• Headset: hope
• Handlebar: BONTRAGER
• Stem: BONTRAGER
• CRANK BONTRAGER
• Front Derailleur: Shimano
£offers
The SCOTT Speedster large features shape optimized double butted Alloy tubing and a race proven geometry that provides an aerodynamic advantage and outstanding performance. With the addition of an Aero Carbon fork, the Speedster 20 boasts F01 racing characteristics at a fraction of the cost.
Frame Speedster Aero / D.Butted 6061 Alloy / Road geometry / Integrated Headtube
Fork Speedster Carbon/Alloy 1 1/8" Alloy steerer
Front Derailleur Shimano 105 Black FD-5800
Rear Derailleur Shimano Ultegra RD-6800-GS
Number of Gears 22
Shifters Shimano 105 Black ST-5800, Dual control 22-Speed
Chain set Shimano RS550 50-34T
Cassette Shimano 105 CS-5800 11-32 T
Chain KMC X11
Brakeset Shimano 105 hydraulic
Handlebar Syncros RR2.0 Anatomic 31.8mm
Stem Syncros FL2.0 1 1/8"" / four Bolt 31.8mm
Wheelset Syncros
Tyres continental pure grip
Saddle Syncros FL2.5
Seatpost Syncros R1.4 Carbon/AL 31.6mm
£700
open to offers on these
SCHWALBE A LUGAND ACTIVE LINE K GUARD 700X28
50% MAXIS HIGHROLLER 26X2.35
50% SCHWALBE MAGIC MARY 27.5 X2.5
NEW SCHWALBE MAGIC MARY 26X2.5
70% SCHWALBE MAGIC MARY 26X2.5
60% SURLY BUD 26 X 4.8
NEARLY NEW SCHWALBE MAGIC MARY 26 X2.25
50% SCHWALBE NOBBY NIC 27.5 X 2.25
NEW MAXIS MINION DH FRONT 26X2.35
70% MAXIS MINION DH FRONT 27.5X2.30
2 SCHWALBE M MARATHON MONDIAL 700X35
https://photos.app.goo.gl/qTGYknxnxfDgmLDe7
spearfish SURLY WEDNESDAY TREK PILOT Speedster and more
