wtd, Wide drop bars. and disc brake levers for drops.
anyone got either please?
Re: wtd, Wide drop bars. and disc brake levers for drops.
I've still got that set-up (Genetic Digest, levers and bar-end shifters) I got off you a while ago. The thing I had planned hasn't happened so you can have them back for what I paid you?
that sounds perfect.
I cant remember how much it was tho, can you??
Brothersmith
Post by Brothersmith »
I got some TPR Hylex in the garage if that's what your after? £110 posted for the pair
I also have Gevenalle rear (right) shifter mount to go with them if you wish? Can do 10sp or 11sp shifter. £85 posted
Brothersmith
Have you got a bit of a conversion going on Tony? Not sure the Genevalle will work with shimano bar ends if for same bike? I take it they landed OK?
ton wrote: Mon Nov 18, 2019 2:04 pm that sounds perfect.
I *think* it was £100 - can't find anything in PM inbox at mo.
They are literally untouched and still have (IIRC) the two layers of bar tape you sent them with.
