Sealskin alternative
Can anyone remind me of the alternative brand to sealskins that was discussed here a while back - there was talk of the alternative being better due to it using a waterproof membane that sealskin had stopped using. It may have all been a cider induced dream, but im sure its somewhere here in this repository...
Re: Sealskin alternative
Think it was Dexshell socks. Although I don't have a pair.
As I understand it, Sealskinz used to use the Dexshell membrane but there was some fall-out.
Another alternative is GoreTex oversocks.
I use the dexshell Wudhu sock as they aren't too thick and are plain black.
My Sealskinz socks are about 20 years old. Are newer versions better?
For me, they are just soggy socks but add warmth as long as I keep moving.
Them ones (the first iterations that felt a bit crinkly) were actuslly better Rasta. They were still using the branded membrane which Dex still use now (Porelle I think) and they lasted alot better than these newer (of the past 9 years or so) Sealskinz... Utter garbage, wuite literallymiddleagedmadness wrote: ↑Thu Sep 12, 2019 9:28 pmNo exactly the same like wearing poly bags on your feet
I have never been in a situation where they have kept my feet dry when it was raining -if the boot gets wet my feet do .Not very breathable either so i think you get wet with sweat from them as well. Would not use on a long ride personally but ok for commuting and night rides.
You’re lucky if they actually work for more than a few rides.
I used to buy a pair every year but gave up some time ago.
Decent wool socks keep your feet as warm (and just as dry ) in my experience.
I use them if my feet will get wet and stay wet. They reduce the flow of water splashing through my shoes. Rainy rides and canoe touring. I think of them as comfortable neoprene booties/socks like a diving wetsuit. When wet, the trapped water warms up.
With this in mind, they work for me.
But I have never considered them breatheable.
The other problem is they take 2 days to dry out.
I had an old pair of Sealkins, they were good at keeping feet warm and (I felt) drier than normal socks. I then got a new pair, they weren't so good.
Some time later, Dee bought me some waterproof Merino Dexshell socks. These feel much more like Sealskins of old. They're a thick sock so your shoes need to be roomy but they generally keep the worst of the water out. However, we shouldn't forget that all socks have a big hole in the top and water will always find its way into it ... even if you tape the cuff to your leg
The newer Sealskinz have a rubber gripper round the ankle. That helps reduce water ingress down the legs but goes baggy after a while.
The longer length ones also suffer less in this regard.
