Head torch recommendations?
Hi all. I've decided my cheapo head torch ain't up to the job anymore.
What would the BB massive recommend for a lightweight head torch for camp duties (not riding)? Nothing too spendy please.
Re: Head torch recommendations?
Petzl tikka or e-lite ,or cheaper there's the alpkit ones
- TheBrownDog
I've got two Petzl head torches, one I bought at Black in 2002 for about £20 that is still working today despite years of use. It's not supposed to be waterproof, but I always wrap a bit of lekky tape around the seal after changing the batteries, and it has survived several dunkings and countless rain storms.
- gairym
Depends how 'good' you want it to be.
For general bimbling around the camp then it's hard to beat the Petzl offerings for value/performance.
But.....if you want to potentially use it for more (and possibly even riding as a backup light) then take a look at LED Lenser.
I bought Mrs Gairy an H8R headtorch for Christmas and at 60€ it's not crazy spendy and at 600 lumens it's perfectly capable as both a camp light and as a backup light.
Usb chargeable and plenty of energy saving options too.
I think they're great!
Petzl Zipka for me. I like that it's not TOO bright as it's less likely to draw attention when I'm pitched up.
- Escape Goat
I use this. You can turn it on from off straight to red and goes all the way up to really bright.
Black Diamond Uomo Cosmo Headlamp https://www.amazon.co.uk/dp/B06W54SB8D/ ... ACb3VM0VFT
I use this tiny petzl one for camp duties when bikepacking and a very bright dimable led lenzer one for hiking stuff. Got an alpkit one I won at the wrt which also gets used most days for dog walking - they’re pretty good value.
https://www.blacks.co.uk/activities/111 ... lsrc=aw.ds
For camp duties I like one that also has a red light to preserve my night sight and, like Scotroutes says, be less obvious when bivvying. A green light is also useful if you're looking at OS maps at night, it preserves your night vision and lets you see contour lines on the map! (learnt that on here ).
I have a Black Diamond one which is small, light and reliable.
- Bearlegged
+1 for different coloured lights. My Alpkit Gamma does red (and I think possibly green, though I never seem to get that option to work; maybe I'll read the instructions some time...).
We use Peztl e-lite too. They are great for setting up camp, eating etc and not calling too much attention to yourself. Very lightweight and compact - weighs only 26g (with batts). Downside is that it's not rechargable so you have to put in a couple of CR32 batts. Definitely no good for riding with but invaluable for pottering about in the dark.
https://www.ebay.co.uk/itm/e-Lite-2-50L ... ctupt=true
ETA - That one ^ has a strap, we have one like that and one that just has a string on it, which is lighter and more compact but needs worn with a hat or it is a bit sore after a while.
Have a black diamond torch storm, had to swap the headband for something more stable, rendered useless with the original headband!
Have two alpkit ones, one for the wifey and one for me. Both torches are similar but the wife’s torch is definitely brighter. Most peculiar!
I’ll be sticking with Petzl in the future
One of the reasons I prefer the Zikpa. I can use rechargeable AAAs.Borderer wrote:We use Peztl e-lite too. They are great for setting up camp, eating etc and not calling too much attention to yourself. Very lightweight and compact - weighs only 26g (with batts). Downside is that it's not rechargable so you have to put in a couple of CR32 batts.
Not wishing to hijack the thread, I'm looking for a lightweight head torch with a rear red led.
I know Vango do one but it’s front lumens are a bit low. I use a Petzl TIKKA plus and clip on a cheap flashing led on the rear but would be interested in an integrated unit if one is out there?
Petzl have a new model the bindi, rechargable so lighter than the 3 x AAA classic types
The Black diamond iota is similar and has the useful feature of a lock to prevent accidental switching on
- JohnClimber
Best one I've found is the Alpkit Qark
It's amazingly bright, focusable and can use small batteries if the included battery runs flat between charges
https://www.alpkit.com/products/qark
I've got an older Qark from Alpkit, which has a rear red light - steady and flashing. Doesn't take AAA batteries as a back up, but does last a long time on low beam, has a reactive mode (good for map reading at night) and is bright for an hour on full.Not wishing to hijack the thread, I'm looking for a lightweight head torch with a rear red led.
No use if no longer available though.
Petzl Bindi
Amazing little thing
Petzl Zipka
Sort of depends on what it's for. small and light, Petzl E+lite - i actually have 4, one of each of the versions and a spare of the zip one. Massively useful little things
My main headtorch is a Black Diamond ReVolt. Usually take the E+lite but the ReVolt is enough to do night walking etc. I used for a pre-dawn start in the Alps last year, navigating on rocks and glacier - it's 130 lumens on max so I reckon I had it on around 80. It's amazing how little light you need, you do need everything else not to have a night sun though
E lite is a great stashaway torch, always find those little disc batteries have a surprisingly long life
Use an Alpkit 3as number for around the farm, the red light mode seems ideal for sneaking up on ewes lambing
My fave for longer trips is the Black rock Revolt (bright enough to use while riding). Like the fact it takes 3as, but has a usb port so can recharge if used with rechargeable 3as.
Really can't knock the Alpkit one overall
Hi,
I use a Petzl Actik core. Light weight and still 350 lumens for an emergency. I bought this one because I can recharge the removable battery via standard USB cable or use AAA batteries instead
Petzl bindi. Best ever imho
Moved from a Petzl Tikkina last year into their e-lite model. The red light is really good for in the pit in the evenings and the space saving is substantial in my gas tank.
Not really a headtorch as such, but what i like about my Exposure Joystick is that it is a long-lasting powerful bike light, but you can then take it off bike and use the seperate headband to turn it into a head torch, saves weight of carrying both, and there aftermarket colour filters that work with it
Id second John climbers offering! Ive seen one these in action and for the money they are great!! They last ages and the beam can be changed, it gives off so much light and the battery can be charged from a dynamo setup. It also has a very good red light more than enough for stealth pitching at night if required
