Battery life on Garmin Dakota 20
ssnowman
Post by ssnowman »
I'm using Ni-MH 2500MAH batteries, but only getting 9-10 hours. I've tested the batteries and they are fine.
Does anyone have any tips for getting more battery life by adjusting settings?
May satan walk with you
Karl
Re: Battery life on Garmin Dakota 20
Post by Karl »
Battery save mode. Turns screen off after few seconds is the best way. Stop the auto pause.
Best way (I assume for the bearbones 200??) Is to use lithium batteries. 2 to 3 sets should do you.
ssnowman
Post by ssnowman »
Karl wrote:Battery save mode. Turns screen off after few seconds is the best way. Stop the auto pause.
Thanks, I've ordered some lithium ones, and it is for BB200.
Lithium's and making sure that as soon as it gets dark you turn the brightness down to the lowest setting should see you right. :-bd
Richpips
Post by Richpips »
I reckon generally about 22 hours for a set of lithiums in plus zero temps.
ssnowman
Post by ssnowman »
Richpips wrote:I reckon generally about 22 hours for a set of lithiums in plus zero temps.
That's a big difference from what I'm getting now!
Chew
Post by Chew »
I usually get the best part of 2 days riding out of a set.
Off the top of my head:
Turn the screen brightness down
You can set the screen to switch off after 30/60 seconds
plus there are a few other things in the options
Might be worth having a look at the settings mentioned here - https://www.navigation-professionell.de ... -settings/
Richpips
Post by Richpips »
....also set record frequency to least often.
Ron Thomson
Post by Ron Thomson »
Set the screen to power off after 10 seconds. This is usually enough time to see you are still on the track as this unit is not much use for anything else. I can get about two days of about 18 hours a day use (tracking and recording) on a set of lithium extremes. Remember to power down when you are sleeping.
ssnowman
Post by ssnowman »
Thanks everyone, hopefully enough tips there for vastly increased battery life :grin:
