Presta and shock pump
Howdy can anyone recommend a small pump that adapts for presta valves and standard fork shock valves? Don't want to be taking desperate pumps with me. Thanks
Re: Presta and shock pump
https://www.specializedconceptstore.co. ... rame-pump/
I have an older version of this. Must be at least 10 years old and it's still good
i had one and it was poor at both options though it sort of worked for both ...just. I then carried a shock pump but I gave up carrying a it as I had not used it in 4 years.
Currently I use a Lezyne pump that will do 120 psi so i can use it for the forks in an emergency
I think you can still buy dual use pumps but dont expect much from them.
There's a few in fact, no idea how good any of them are mind. BBB do one, Beko also....here's a Cannondale branded one, but it looks pretty much like the Beko offering.
https://www.tredz.co.uk/.Cannondale-Air ... gLTZvD_BwE
Judging by the responses ... this may in fact be true.Don't want to be taking desperate pumps with me.
Thanks for the replies. Not sure where desperate pumps came from! I'll check them out later.
If you really need a shock pump, there are a few around like this, only 48g https://www.evanscycles.com/topeak-micr ... p-EV162341
