Good morning all. So having got a new chain ring at home! The one I'm using has started to dump the chain all of a sudden when I ride rocky stuff. Any chance anyone has a spare part used one I can use just for Jennride at all please. Not fused if it's a 30 or 32 if anyone can help that would be great juSt to get me through the weekend
Ta
Oh it's a 4 bolt 104
Jennriders please read
- Dave Barter
Re: Jennriders please read
Is it a clutch mech? Mine did the same with a new chainring.
The cage was sticking a bit on high gears causing slack.
It turned out the solution was to loosen the Allen bolt holding the cage on a half turn. This is the one in the clutch box held on with 3 small bolts.
Yes dave, it's an XT with clutch. I will try that as it does feel a bit sticky
10spd?
I've a couple of spare NW chainrings, I'll shove them in the car before we head over.
Cheers all 10 spd yes matt
