Garmin Edge Touring giving me trouble ... help please
- TheBrownDog
I'm trying to load Pickers' three WRT routes onto the thing, but it just won't play nicely. I've tried clicking and dropping the files in the New Files folder. They show up on the computer in FINDER but not on the device. I've "saved as" and I've copied, cut and paste .... nothing. Ive turned it off and turned it back on again. I've deleted most of the other files in case the memory was mucking up.
Any thoughts? They are straightforward GPX files just like the half a dozen others Ive got on there.
Re: Garmin Edge Touring giving me trouble ... help please
Try using Garmin Basecamp???TheBrownDog wrote:I'm trying to load Pickers' three WRT routes onto the thing, but it just won't play nicely. I've tried clicking and dropping the files in the New Files folder. They show up on the computer in FINDER but not on the device. I've "saved as" and I've copied, cut and paste .... nothing. Ive turned it off and turned it back on again. I've deleted most of the other files in case the memory was mucking up.
Load GPX into basecamp
Connect Garmin to computer via USB cable
Send to internal storage of Garmin
Pretty sure that GPX files need to be in /Garmin/GPX folder before the device will read them...but I could be horribly wrong. :)
Tim, I have an Edge Touring as well, sometimes it doesn't play well with either GPX tracks or routes - they all need to be one or the other, can't remember which. Basically if they're the wrong one they won't show. Don't ask why this is, it's a Garmin foible.
I normally do routes on Bikehike and save as GPX routes I think - this has come straight off Memory Map which might work differently - they're first drafts so they'll be tidied up anyway yet.
We’re gonna need snacks
#TakeLessBike
#TakeLessBike
I find that if it's a tcx or gpx trail it will work in Basecamp but not Garmin connect , the only way I can load into connect is to use a gpx route
- Dave Barter
It could be that the GPX file is route points rather than track points. Garmin devices usually only like track points. If you send me the GPX I can check and fix. dave@phased.co.uk
TBD you could also open each one in bikehike.co.uk and then save them as gpx track. I have edge touring and the folder is new files.
On my 800 they gpx or tcx files need to be put in the new files folder. On the etrex they go in the gpx folder.
Don’t know how the menus are structured on the touring.
Just like the 800, new files. I have both.
If at first you don't succeed, destroy all evidence you ever tried.
- TheBrownDog
Brilliant thanks everyone. Sure one of those tips will sort it. Dave thanks for the offer. Will take you up if all else fails.
- TheBrownDog
Right. Sorted. Opened one of the routes in bikehike and after failing when I saved it as either form of gpx, saved it as a tcx and lo and behold, it appears on the gizmo. Very odd. Ive had this thing for years and never had an issue with it. I would not have been a happy camper if that had happened the night before the WRT.
