I've been using an Alpkit Airlok Tapered dry bag in my Wilcat Tiger Seat pack for some time now, but was never really satisfied with how the seat pack straps sat, on top of the dry bag closure buckles...
Messy straps by belugabob, on Flickr
So, a bit of work with the sewing machine, a length of webbing and the appropriate buckles, provided a much neater solution...
New Strap, step 1 by belugabob, on Flickr
Clip the fixed end of the strap, to one of the dry bag buckles...
New Strap, step 2 by belugabob, on Flickr
Clip in the other end, then cinch down
New Strap, step 3 by belugabob, on Flickr
Put it back in the seat pack - that's better!
New Strap, step 4 by belugabob, on Flickr
Now, how many grammes have I just added?
Seatpack improvements - simple, but effective
Re: Seatpack improvements - simple, but effective
Isn't that how it's supposed to be used anyway?
I'm sure mine came with the necessary strap already. Going to have to rummage in the garage now just to check I've got an overactive imagination.
Hmmm,
The main picture on the Alpkit page does suggest that it comes with a single strap, for attaching to the saddle rails.
Mine may have been supplied with this (but I had it a few years and my memory is become rather suspect) and I may have removed it, due to using the bag in my Wildcat harness.
Some of the pictures further down the page - particularly those which show it mounted to the bike - suggest that two straps may be supplied.
Other picture don't hint at a second strap, and show the bag closed in the way that I used to close mine.
The strap (or straps) may be hiding somewhere, but I can't help thinking that I'd have used the supplied ones in the same way as the one that I've since made.
I'm wondering if these have been added to the package since I got mine...
I've had mine some years and it didn't come with straps. The double ended dry bags I have did come with a pair of straps. I think the make of buckles has changed over the years as well? so not all straps will fit onto the closure of all bags,
Had a look at mine last night. I realised I've been using it differently of late. Mine definitely came with two straps, one to hold the roll top as in your mod and the other to strap to the saddle. Funny enough, of late, I have been using a much larger saddle pack and sliding the alpkit bag in. Means I don't have to remove the luggage from my bike, I just pull the inner when at camp. Anyway, in this config I found it easier to clip the roll top to itself as it works as a pull handle.
Anyway, apologies, I hadn't meant to detract from your good work!
No worries - it all adds to the discussion.Nevis wrote:Had a look at mine last night. I realised I've been using it differently of late. Mine definitely came with two straps, one to hold the roll top as in your mod and the other to strap to the saddle. Funny enough, of late, I have been using a much larger saddle pack and sliding the alpkit bag in. Means I don't have to remove the luggage from my bike, I just pull the inner when at camp. Anyway, in this config I found it easier to clip the roll top to itself as it works as a pull handle.
