Wet the bed.
Wet the bed.
Used my Rab Survival Zone for the first time last night on Dartmoor.
Bivi'd in thick mist and woke up soaked. Not great in a down bag.
Not only was the inside of the bag wet (I guess from not breathing) but also my feet were soaked where they had been out all night and the water had come through.
On its way back for a refund.
So, new one needed.
Recommendations please!!
On the plus side, my new Klymit mat and pillow were great.
So, new one needed.
Re: Wet the bed.
In all honesty that sounds like what happens in the vast majority of bivvy bags, if the conditions are right. Your best chance of avoiding it is to go for something that's made from either Gore-tex or eVent (expensive option) or get one which isn't actually fully waterproof but is very breathable (less expensive option).
These days I favour a very breathable, water resistant bivvy bag along with a tarp ... sleeping out with just a bivvy bag can be a bloody miserable experience.
Re: Wet the bed.
Unfortunately I was under a tarp which makes it worse.
Which one are you using at the moment?
Re: Wet the bed.
The Borah Gear bag is my favourite at the moment.Which one are you using at the moment?
http://bearbonesbikepacking.blogspot.co ... y-bag.html
If you were under a tarp then it's fair to assume you were suffering condensation rather than a leaky bag ... you didn't end up with it pulled over your face did you?
Re: Wet the bed.
No, although it crossed my mind. My feet were soaked from the dew and mist.
The Borah looks the business. I take it you've got the 1.1 DWR? Did you get one with the hood option? And do you need the extra long zip?
Re: Wet the bed.
No, mine's M50. M90 is slightly more breathable, slightly less waterproof and a little heavier. Full net 'hood' and the extended side zip.I take it you've got the 1.1 DWR? Did you get one with the hood option? And do you need the extra long zip?
Re: Wet the bed.
I can recommend the MLD Soul eVENT bivy as totally waterproof & very breathable, but it is quite expensive.
Re: Wet the bed.
The Soul eVent looks interesting, I was considering a MLD Superlight as it zips up fully (like the Soul) however has a small moon shaped air hole to keep condensation low.
I notice however the Soul has no breathing hole! Have you used this fully zipped up in wet conditions? Aren't you at risk of suffocation?
MLD Superlight : http://www.mountainlaureldesigns.com/sh ... ucts_id=30
Re: Wet the bed.
I'd never fully close up the main body of the Soul (the eVENT bit), but there's also an integrated strip of bug netting that I do zip up if I want to keep the worst of the wind out. If it's pouring with rain and you don't have a tarp over your head then you can use the double zippers on the main eVENT body to leave a few inches open low down to minimise the chance of water ingress but still allow you not to die of asphyxiation during the night. Fortunately I've only ever been rained on in the bivy when I've had a tarp over my head so it wasn't an issue.
Re: Wet the bed.
Ahh I see. So the main difference between the superlight and the soul seems to be the top fabric. eVent v's Endurance 10D 3X DWR.
I will add the soul to my wish list and delete the superlight.
