Wtd. Avid post to post brake adapter
Guys I'm in need of a 185mm front post to post brake adaptor for a new build if anyone has 1 lying around. Probably be an Avid or Hayes. Cheers
Re: Wtd. Avid post to post brake adapter
I have used 5 mm spacer on the end of a standard 180mm post mount adaptor (bolted end) when I was using a 185mm avid disc with std shimano components.
- BigdummySteve
I’ll have a quick look I’ve just taken a 180ish disk off my Fargo
- BigdummySteve
Wrong size, only 180, I’ve just bought one for the rear, it was only £6.50
- Dave Barter
Hux. I think I've got one don't buy anything util I've had a ferret about in the garage.
- Dave Barter
Damn its 180, sorry
No worries,thanks for looking guys. Think Zippys idea might be the way to go.
It was a while back now, iirc, it was the spacer blocks from some V brakes that I used. Had no problems, including descending off Snowdon where I think I got brake fade (on a bicycle) for the first and only time in my life!
Ud better get that new bike built before mon pal so we can go out!!
Just waiting for the forks pal
Hux,
After much routing and searching, I have found the offending article!
Avid 185mm post to post adapter.
Chuck us your address across and I’ll get it in post.
Call it good karma, mate. Also wouldn’t like to think of anyone packing out their brakes with washers????
Artie ygm
