Velogical Rim Dynamo Experiences?
Shameless steal from STW , thoughts about longevity and output. Would it be the answer to powering lights and gps without needing a wheeel rebuild or replacement if standards change. Seems typically German build quality.
http://www.velogical-engineering.com/ve ... -efficient
Re: Velogical Rim Dynamo Experiences?
Interesting Duncan. I've being waiting for someone to produce something similar ... I don't really see a downside.
I'd be worried about fragility and its use on muddy rims but it could work for road use.
- Dave Barter
Off the wall suggestion from me, but could you engineer something that retrofitted at hub level to avoid the mud situation that I fully empathise with.
Hmm, not convinced this is aimed at us folks. Road certainly, off road...no, not so much.
It relies on the higher velocity of the rim.Dave Barter wrote:Off the wall suggestion from me, but could you engineer something that retrofitted at hub level to avoid the mud situation that I fully empathise with.
There's a few out there - this one even works with disk brakes. Whether it works with 12mm through axles is another thing...Dave Barter wrote:Off the wall suggestion from me, but could you engineer something that retrofitted at hub level to avoid the mud situation that I fully empathise with.
https://www.amazon.com/Tigra-Sport-Bike ... 175c5971c2
Isn't it a new version of the bottle dynamo? Or am I missing something?
- Dave Barter
Surely every point on the wheel has the same velocity?ScotRoutes wrote:It relies on the higher velocity of the rim.Dave Barter wrote:Off the wall suggestion from me, but could you engineer something that retrofitted at hub level to avoid the mud situation that I fully empathise with.
But you meant angular velocity didn't you.
Yes and no.Isn't it a new version of the bottle dynamo? Or am I missing something?
I hope he did.Dave Barter wrote:ScotRoutes wrote:
...But you meant angular velocity didn't you.
Now, to put an aeroplane on a treadmill....
Obvs!!Dave Barter wrote:Surely every point on the wheel has the same velocity?ScotRoutes wrote:It relies on the higher velocity of the rim.Dave Barter wrote:Off the wall suggestion from me, but could you engineer something that retrofitted at hub level to avoid the mud situation that I fully empathise with.
-Edited now I had coffee-
Bottle dynamos though, yes, I'd give one a go if the weight and output compared to a hub dynamo.
- stevenshand
I had a chat with the guy behind this last week :
http://ridelo.cc/
there's scant information on the website but some of the figures he was talking about seemed pretty impressive. I'll see if I can dig out some more info.
http://ridelo.cc/
