DIY bar harness 'spacer' foam.
ctznsmith
Post by ctznsmith »
Maybe this should be in the MYOG section but what have people used to space a bar harness off the bars/cables?
Current idea in my head is to get some cheap flip flops and cut squares from the soles/base.
firestarter
Re: DIY bar harness 'spacer' foam.
Post by firestarter »
I've seen a bit of plastic plumbers tubing that worked well
Adventurer
Post by Adventurer »
I've used some pieces cut out of gym flooring.
The square foam mats that you put together. Think I bought them from Argos a while ago.
techno
Post by techno »
ctznsmith
Post by ctznsmith »
Realised I am of the more 'frugal persuasion' so didn't really want to buy anything.
Looked at the foam backed bar tape that came off of the Digest bars I'm selling.
Chopped into squares and created a tower.
Wrapped in Gorilla tape for longevity.
Job done! :wink:
Stuart, do you want to move this to MYOG?
mechanicaldope
Post by mechanicaldope »
Sure they're not going to work their way out sideways? Can't see if you have physically attached them somehow or if they are just jammed between the bar and the harness.
ctznsmith
Post by ctznsmith »
mechanicaldope wrote:Sure they're not going to work their way out sideways? Can't see if you have physically attached them somehow or if they are just jammed between the bar and the harness.
Just jammed in. We'll see, but with the straps tight they shouldn't go anywhere.
Rich3rd
Post by Rich3rd »
Might be a bit OTT, but very sturdy http://www.chainreactioncycles.com/tope ... -prod74876
I've used 40mm plastic waste pipe. Drilled a hole through it with a 32mm hole-saw, then cut the pipe through the hole to give me two semi-circular stand-offs that fit nicely round 31.8mm diameter bars.
