back to news and reviews
Posted by
I think it’s fair to say that the majority of the bikepacking world are now firmly of the belief that not using a backpack is a good thing and rackless carrying systems are the way forward … those who don’t subscribe to the above have probably never ridden for 100 miles with all their gear on their back and have never had a rack snap miles from home.
One of the criticisms often leveled at bikepacking luggage is the fact it’s usually not waterproof, water resistant certainly but not actually waterproof … after all, dry bags are now as synonymous with bikepacking as any other piece of kit you could name. You know the score, pack all your rather expensive kit into dry bags, then pack all your dry bags into all the other bags adorning your bike … that’s right, you’ve just put a bag inside a bag – WHY? … is one bag not enough?
In my opinion this is where the Wildcat Gear Tiger comes into it’s own … it’s possibly as near as we’re going to get to being bagless.
8L Dry bag happily strapped to a Tiger.
The Wildcat Tiger isn’t a bag, instead it’s designed to hold a bag. I should say here, that it’s not just designed to hold a bag … it’s designed to REALLY hold it, without any of the swinging and swaying sometimes associated with rear bags. It attaches to the bike around the seatpost and the saddle rails. The strap around the seatpost has some kind of ‘rubber’ on the inside which aids grip and I’m sure also helps to stop your post getting battle scars. The two saddle rails straps are quick and easy to fit and adjust … the whole thing can be on and off in under 30 seconds. The strap system is fully adjustable, so you should be able to utilise most makes of dry bags. Purely in the interests of research, I completely over loaded this one, then rode the bike down some of the roughest trail sections I could find. The result of my ‘research’? Nothing, nothing at all … I forgot that it was there, it didn’t do anything to remind me it was there, so it’s not surprising I forgot. While Wildcat don’t endorse this kind of behaviour, it’s nice to know ;o)
There are two sizes of Tiger available, I’ve given the larger version a real battering over the last couple of months. It’s held everything from some butties and a few tools to the biggest tarp you’ve ever seen plus pegs and groundsheet. Other times it’s carried my sleeping bag, my cooking kit and food … pretty much whatever I’ve wanted it to, without any fuss or drama. A quick run under the tap has it looking nearly as good as new.
All the materials used in its construction are the best available and as with all Wildcat products , the attention to detail and craftsmanship are faultless. However, what makes it great in my mind is the fact someones actually thought about it and found a better way. I’m sure it would have been easier to just knock out another rear bag that does the same as all the others … it allows you to put a waterproof bag inside one that isn’t, say it like that and it seems quite mad doesn’t it.
3 Comments
  1. Anonymous says:
    I recently purchased the larger version of the Tiger and am really impressed with it. I would agree with everything Stuart has written; I can't fault it.
    I can't see myself using a backpack from now on for most of my rides.
    A great piece of kit 🙂
  2. Unknown says:
    What a simple and clever idea that "expands" to fit whatever stuff sack you use. I had never heard of Wildcat Gear before so thanks for the info.
  3. Just ordered this, hope it's good
Comments are closed.
You may also be interested in
Read Full Article
Read Full Article
Read Full Article
Shopping cart0
Continue shopping
Privacy Overview
