North South Divide GPX?
Did anyone ever produce / find a gpx for the North South Divide route as I'd be very interested in a copy.
Re: North South Divide GPX?
Think Mr Fitz was working on somwthing
Email heading your way Stu. I've ridden it in reverse as far as North of Loughborough. When you're going to do it shout and I'll meet you at the end or join you for a bit if you don't mind!
Nigel you are a gent, I'll give you a shout. I'll probably be ready for some company by then
When were you thinking of having a go?Bearbonesnorm wrote:Nigel you are a gent, I'll give you a shout. I'll probably be ready for some company by then
The Thetford section might be a bit out of date, I haven't ridden there for a while and I know there has been some changes to the trails.
Probably not until the start of spring.When were you thinking of having a go?
Good idea. Theres a section between Peterborough and March that is clay with a thick coat of leaves and a Bridleway Metfield/Bungay way iirc that is just the worst mud imaginable.Bearbonesnorm wrote:Probably not until the start of spring.When were you thinking of having a go?
