Thermos / Flask that fits in a bottle cage?
Is there such a thing? One that wouldn't pop out on the rocky stuff?
Basically I am lucky enough to work from home a day or sometime more a week. This means I can take an hours lunch break and go for a ride. Its 50/50 road nice trails and it would be nice sometimes to take 5 minutes with a brew.
I know I could take a meths stove etc, but that would turn into 15 minutes to have a brew.
Ta.
Ta.
Re: Thermos / Flask that fits in a bottle cage?
I suppose you'd need to find the external diameter of the flask and get one that is close to that of a water bottle. The small flasks tend to be too thin and the larger flasks too wide. I haven't checked the B2B flask though, which seems a little wider than most small flasks. There might be an issue with the metal outer of the flask and the metal of the cage as most water bottles are plastic so there's a bit more friction metal-plastic than metal-metal.
Get a monkii cage and then you can carry whatever you like.
Trail 42 do one that's a perfect fit. My mates has been fine, mine stopped working after not much use (wasn't dropped, put in dishwasher, etc). When working it'd keep a coffee decently warm for at least 40 mins, probably longer but wouldn't know as that's how long my commute is!
My cage is plastic.
I dont want a monki cage as I want to use my normal bottle cage without the strap etc most of the time. Good Idea though
The BB flask is a touch too small.
Dave have a look at the Klean Kanteen range, good stuff although not cheap.
- adjustablewench
Not massive but I have one of these which is very good
http://www.trail42.co.uk/products/pack-flask
You could bend the top part of the bottle cage inward so that you get a fit. Might need to wrap some tape around it as well to improve the friction between it and the flask.
Cheers chaps.
Trail 42 and Klean Kanteen look up to the job, my quick lunchtime rides are set to be even better
I got one of these from clas ohlson. Fits in my bottle cage.
http://m.clasohlson.com/uk/Asaklitt-Vac ... r315510001
Edit: silver unfortunately
You Tube:
Trail 42 flask is a touch too small in diameter but a couple of wraps of insulating tape/duct tape/helicopter tape would make it a snug fit.
Just been browsing the kleen kanteen website, the lifestyle photo's made me laugh quite a lot...
Try outdoorgb Dave, decent range and prices without the toe curling pictures
A Lifeventure thermo mug fits tight in an old chopped off water bottle. They had a deal on the mugs in Cotswolds recently. I am sure that the extra layer of plastic must help as on a cold day you are running an efficient heat exchanger on your down tube !
+1 for the lifeventure mug. Brilliant piece of kit. Have used them for 10 years at least. Perfect fit in a chopped of bottle, snug and tight. As I'm still in the service I use them a lot, hot days, cold days..Everyday. When biking, I make my morning coffee, and make some more for the thermo. Unless very cold (like today -16), it will hold the coffee warm until noon. Not standard issue in my army, but I think every soldier have at least one (perfect fit for ammo pouch )
Lars
Lars
http://www.elite-it.com/en/products/bot ... les/deboyo
Bought one of these last year for my brother. appears to be great and is designed purely for bottle cages. Think I saw a photo of Cavendish using one for tea on a training ride not so long ago.
i wanted exactly the same for a coffee on my commute, I bought one from charliethebikemonger.com
Nice bit of kit and is specifically designed as a bottle holder flask cant remember brand but give him a ring and he'll sort you out.
Wait for me...
Bought the OH the trail42 for Christmas, she has been using it in a bottle cage succesfully (although some of the paint is scraping off ). She also likes it enough she's started taking it with her when travelling for work.
I'm jealous, I may buy one....
an elastic strap or something might finish off the puzzle to stop the flask self ejecting.
- macinblack
TK Maxx often have Kleen Kanteen in.
I have one made by biologic that fits in a cage. Fine for road and easy trails but jumps out on rough ground.
As others have said a screw top mini flask in a pocket or small bag will work well
This is what I use as a bottle carrier. Fits 51-73mm OD
http://www.topeak.com/products/Bottle-C ... dulaCageEX
There's also the JavaCage if you want a bit more security (back to using a rubber strap though)
http://www.topeak.com/products/Bottle-C ... lajavacage
I've ordered one of these
http://www.outdoorgb.com/p/Klean_Kantee ... tem=675132
The stated diameter is the same as a water bottle, Just hope the ridge is in the right place.
Thanks very much for all the suggestions. I'll report back on my choice when it arrives.
I have a trail 42. In a metal cage it can be a bit rattely. A bit of electrical tape on the cage and it is all good.
Not a huge volume, but I can't really fault it.
