How to insert pictures
woodsmith
Re: How to insert pictures
Post by woodsmith »
Old Aliens
Post by Old Aliens »
Test.
I've also had a few problems embedding picture from Flickr.
If I try to share from the Flickr app (android) the instruction make no sense as far, a getting the correct url code.
but if I go to Flickr.com the instructions make sense.
bluebus200
Post by bluebus200 »
bluebus200 wrote: Thu Dec 24, 2020 5:05 pm Image7A61AE7C-0C77-4CDB-B3BC-0EF6FFD954CF by Chris Harris, on Flickr
I have those type mudguards, brilliant. They actually work and less bike cleaning :-bd
bluebus200
ledburner wrote: Thu Dec 24, 2020 9:12 pm
I like it, but it does still leave my motor and some wiring prone to splatter! I need to invent something for the rear I was thinking of using an old tyre. This project is turning into a rolling junk yard.
I added, a, section of old mudguard to the front, rivited on The donor SkS guards were good but in sat too high up. The soft lowerflap a bonus.
I made a rear guards out of LDPE sheet. It fits I. The rear triangle and is addition to the standard seatpost reguard. The LDPE is soft so it has reinforcement to make it more ridid & Shape it. I tried using hdpe but it was too noisy.
(141.29 KiB) Downloaded 788 times
JKM
Post by JKM »
testing, testing ....
can anyone else see the picture or is it just me?
JKM wrote: Tue Jan 12, 2021 1:26 pm testing, testing ....
Nope.
Looks like you are trying to link a picture on google images. That's tricky. Pretty sure there's some instructions somewhere on this thread.
JKM
Post by JKM »
how about now?
edit: nope, even i cant see it now.
3rd try
JKM wrote: Tue Jan 12, 2021 2:37 pm how about now?
You've linked to the page that the image is on not the image itself. The image link needs to end in ".jpg" or other image file extension.
JKM
Post by JKM »
whitestone wrote: Tue Jan 12, 2021 2:42 pm
great, thanks
I use this website:
https://www.publicalbum.org/blog/embedd ... otos-image
Go to your picture in Google Photos, and use the Share Image function to create a link to it.
Copy the link into the above webpage, and it will generate a code. Copy this code, and add it to your post using the image function (adds Image tags to your link).
JKM
Post by JKM »
thanks.
how about this?
I can see that. Bit confused by the blue stuff in the background, and the suspiciously high light levels mind you...
Landslide wrote: Tue Jan 12, 2021 2:45 pm I use this website:
Thanks that'll save me reducing photo down to 800x 600. Claim a gold star and go to the top of the class! :-bd :d
The Cumbrian
Post by The Cumbrian »
Test
Bilbo Baggins.
You just need to add the [ IMG ] tags for that to work.
The Cumbrian
I'm suffering a breakdown in understanding.
Bilbo Baggins.
The Cumbrian wrote: Sun Jan 17, 2021 5:51 pm I'm suffering a breakdown in understanding.
Click on the image icon above the text entry box - looks like a mountain with a sun/dot to the upper left. That gives you this:
[ img][ /img]
(I've added a space after the initial [ so the forum software doesn't mess with it)
Now put your image address inside the above pair of tags like.
[ img]https://live.staticflickr.com/65535/508 ... 54ae_z.jpg[ /img]
Which without the formatting spaces gives
Or should except dropping that image address into the browser bar gives a "can't be found" message
The Cumbrian
Thanks for the help, I got there eventually.
Bilbo Baggins.
shutuplegs
Post by shutuplegs »
Test
shutuplegs
Seems to have worked, thanks to Whitestone and landslide for the instructions above^^
Andiphim
Post by Andiphim »
Andiphim
Post by Andiphim »
