Having a spring clean and bike part swaps, so everything must go!!!
* On One Ti Inbred 29er (Lynskey built) frame - 19 1/2" Medium. Slot Dropouts. No decals, bead blasted finish. A few rubs from frame bag. vaguely exciting frame that will run S/Speed or hub gear. - £550.00 posted.
*Pace RC-31Rigid Carbon Fibre Forks - 440mm axle to crown. 178mm 1 1/8" straight steerer, SFN fitted. Seen plenty of use, a few scrapes and scratches. Rub on underside of crown from handlebar harness. Overall scruffy appearance but totally usable. Priced to suit - £55.00 posted. ****SOLD****
*Shimano Alfine 8sp. Hub - Black 8 speed hub, 32h, 18t Alfine sprocket, Wet weather cassette joint, black Alfine rapid fire type shifter, inner and outer cable. All you need to go! Bought new and has done about 100 miles max!! All as new. - £100.00 posted.
*Chris King Notreadset Bottom cup only - Yes, bottom cup only supplied with fork crown race. Blue anodising. 1 1/8". Good condition, usual fitting and removal marks but nothing you won't see when fitted! - £15.00 posted. ****SOLD****
*FSA Carbon Pro Cranks - ISIS Drive, 175mm crank length, 110mm BCD spider. Very good condition, all treads good. No rings or c/ring bolts. Complete with FSA Platinum Pro Titanium MegaQuad Bottom Bracket - ISIS Drive, 113 x 68mm, FSA alloy crank bolts.Very good condition. - £100.00 posted
*Bontrager Ranger 29er Single Speed Wheelset - All black, 6 bolt IS hubs, 135mm OLND rear sealed bearing hub, Q/R axles. No skewers supplied. Round, straight and true. Decent set of starter S/S wheels. - £60.00 posted.
*Kenda Small Block Eight 29 x 2.1" wire bead tyres. One pair, almost new condition. Only done 75 miles max. - £20.00 posted
*Knog Blinder Road 3 LED Front Light - 300 lumen max output. Gunmetal grey colourway, comes with USB extension cable. Excellent condition. - £35.00 posted.
*Snugpak Special Forces Bivvy Bag. - Olive green, comes with stuffsac. Excellent condition, waterproof and breathable. Has the 1/2 zip on the top! - £33.50 posted.****SOLD****
* Bikebag Frame Bag. - Very similar to an Alpkit style bag, very weather proof material, 2 zips on drive side, removable divider and long velcro fastenings on 3 sides. Very secure when fitted and large capacity.
520mm Top tube
360mm Seat tube
640mm Down tube
60mm Wide
Will fit the Ti Inbred I have for sale, will also fit medium steel Inbred frames. A bit muddy, but will do my best to get it off before shipping! - £40.00 posted.****SOLD****
* Paramo Mens Velez Adventure Light Smock - Size Large, Red/ Grey colourway. As new condition, worn once! Can supply all tags and guarantee card. Really nice jacket, but sadly isn't going to get the use. - £110.00 posted.
Can combine postage if necessary, willing to discount for multiple purchases and generally haggle!!!
Post up here, PM me or email :- mrbarry66ATgmailDOTcom
Can do plenty of pics, email me.
Many thanks!
FS: Spring Clean Clearout!
Last edited by Artie Fufkin on Tue Mar 10, 2015 12:14 am, edited 2 times in total.
Re: FS: Spring Clean Clearout!
I have the same T'inbred frame. Tempted to buy a second but bank balance will prevent it for now
Interested in the frame bag and king headset and crown race. If you could post them for £50 I'd take them. Can make the arrangements by pm.
