Carbon pegs
Carbon pegs
Stu - do you reckon you could make a UK equivalent these?
Your carbon poles look properly strong enough for it
http://www.rutalocura.com/Tent_Stakes.html
- adjustablewench
Re: Carbon pegs
Ooh nine inch carbon nails - how cool
Re: Carbon pegs
Possibly, I'll have a play. The bonding of the tips will be the weak point but I might have an idea that negates itStu - do you reckon you could make a UK equivalent these?
Re: Carbon pegs
Carbon isn't well known for it's abrasion resistance...
Be interested to see what you cone up with.
Re: Carbon pegs
The way I see it doesn't really need to be, as the aluminium tip will take the brunt of any rocks.Carbon isn't well known for it's abrasion resistance...
I use Easton nano pegs and they are similar hollow aluminium tube with solid machined point and they are very tough.
Re: Carbon pegs
The peg will only go in and out of the ground once every 24 hours* Zippy. Yes, it'll scratch but I don't think that'll produce enough wear to cause any issues.Carbon isn't well known for it's abrasion resistance...
*In most cases.
Re: Carbon pegs
I gave it a little bit more thought. I've seen carbon fibre used in far harsher environments and they're fine for that. I suspect even lots of use at Strathpuffer (i.e. Mica in the soil) and they'd be fine.
Re: Carbon pegs
Did you ever give this a go Stu?Possibly, I'll have a play. The bonding of the tips will be the weak point but I might have an idea that negates it
Re: Carbon pegs
I worked it out, actually I worked out an initial plan which could change once I started but need to order the raw ingerdients.Did you ever give this a go Stu?
Re: Carbon pegs
Ready to be chief tester for you when they are ready
Re: Carbon pegs
Sorry for the long delay in sorting something, finding carbon up to the task took a little doing. Anyway, 150mm long 'nail', 6g and so far seems pretty much unbreakable. Testing begins next week.
Re: Carbon pegs
Natty.
Re: Carbon pegs
Looks cool and a similar eight to my Ruta pegs.
What's the spike made from and what diameter carbon?
Def. interested in this....
Re: Carbon pegs
These are 6mm O/DWhat's the spike made from and what diameter carbon?
Now, my issue with carbon pegs has always been the tips falling off or remaining stuck in the ground when you remove the peg. Obviously you need to bond a tip onto the carbon tube and it'll always be a weak point, there isn't much surface area unless you make the tip very long and that makes things heavy.
In an effort to negate the 'tip issue' these don't have any ... because they're one piece, made from carbon rod.
Re: Carbon pegs
Interesting. Reckon they'll pull much in sandy ground?
Re: Carbon pegs
I think 6mm O/D @ 150mm long might not be the most secure but if you increased the length or diameter (maybe 8mm), I think they'll hold well.Interesting. Reckon they'll pull much in sandy ground?
Re: Carbon pegs
Thread resurrection...
Is the dyneema on the peg reflective at all? I've a habit of losing pegs in heather and at £3 a pop anything that helps me retrieve them would be good
If not, I'll just order up some cord.
Re: Carbon pegs
No Colin, it's just bright.Is the dyneema on the peg reflective at all? I've a habit of losing pegs in heather and at £3 a pop anything that helps me retrieve them would be good
Re: Carbon pegs
Which is more than I am - especially after a night in the hills. Hence me losing bloody pegsBearbonesnorm wrote:No Colin, it's just bright.Is the dyneema on the peg reflective at all? I've a habit of losing pegs in heather and at £3 a pop anything that helps me retrieve them would be good
Re: Carbon pegs
This might be a bit 'moon on a stick' but would it be possible to notch these so they 'catch'/'hold' the guy line at the top?
(clearly putting them into the ground at the 'correct' angle negates this but sometimes the ground isn't that forgiving)
Re: Carbon pegs
I'll try one Ben but obviously any notch or cut is a potential stress raiser ... something carbon doesn't like.This might be a bit 'moon on a stick' but would it be possible to notch these so they 'catch'/'hold' the guy line at the top?
