CODEPAK Bike Cargo Solutions
Re: CODEPAK Bike Cargo Solutions
thats pretty funny
- mountainbaker
Dumb. But then some dude who walks 21 miles towork in detroit raised $70k of 'middle class sympathy backing' from kickstarter.
Not for weight weenies.
The aluminum weighs 538 grams and the carbon weighs 425 grams. We built these boxes 4" wide.
Blog - thecyclerider.com
Just how difficult is a zip to operate?Having a push button latch a CODEPAK is the easiest to open pack you will ever own
Anyway, that's me off into the workshop
Don't forget the "aerospace latches"!
Cut out the middle man and weld a head tube and rear triangle onto a tool chest.
- Dave Barter
or just have a rack and coat hangers..
How about small hatches on the frame of the bike so you can put stuff inside the tubes? Tent poles, pepperami's.... dry spaghetti. Or fill it with water and attach a hydration pipe to the bottom bracket?
Edit - if I see these ideas on Dragon's Den I will be unhappy
It'll stop yer sarnies getting squashed
Yorlin wrote:Don't forget the "aerospace latches"!
is it made out of Aerospace Aluminium and Aerospace Carbon Fiber Technology ?
Looks like a good way to shave the fat off the inside of your legs
I'd like some made using the aerospace technology the Mosquito or Hurricane used.
I've got an extra internal routing hole on my fatty for a dropper post, so that would work. Perhaps use it as a spoke dispenser instead of spaghetti as there's no guarantee I'd use up all the spaghetti before it went out of date.Yorlin wrote:How about small hatches on the frame of the bike so you can put stuff inside the tubes? Tent poles, pepperami's.... dry spaghetti. Or fill it with water and attach a hydration pipe to the bottom bracket?
