Except that CO2 will populate a Stans Bunny in the space of less than a week, so you're better off with "clean" airRichard G wrote:Those airshot things are interesting. It makes me wonder how many tyre swaps you'd need to be making to make it a better option than CO2.
I imagine they're fantastic if you're a racer though.
Could you use co2 to seat the tyre then reinflate with a track pump? Or would the presence of left over co2 still screw things up?Ian wrote:Except that CO2 will populate a Stans Bunny in the space of less than a week, so you're better off with "clean" airRichard G wrote:Those airshot things are interesting. It makes me wonder how many tyre swaps you'd need to be making to make it a better option than CO2.
Ben, the latter has been my experience in the past. I view CO2 as emergency use for short periods only
I only use CO2 for seating / emergencies.
Takes all of 10 seconds with a track pump to fill it after it's seated.
Well, that was easy. Removed tubes, fitted valves, chucked in a load of stans and used the airshot. Went straight up!
Tubeless ahoy! by DKNWHY, on Flickr
You Tube:
Full 105 groupset, syncros bars and mavic wheels arrived yesterday
Some nocks and nocking pliers for my longbow ... exciting.
The only group of people that can get excited over guylines...how sad...barney wrote:some new guy lines and line locks for the new tarp-tent
You should see how chuffed I was when I bought titanium tent pegs
new brake hose and fitting kit to fix the YD300 damage plus new pads and rotors from superstar JULY25 25% off offer.
I know some folk don't like SS but i've always found them OK.
Webb H12R
Sad, I know,
but I'm disproportionally chuffed with this. No Engine, No cable. Check out the stripes. . And I get some exercise pushing it.
Sad, I know,
Last edited by frogatthefarriers on Sat Jan 26, 2019 3:40 pm, edited 1 time in total.
What grips do you have on it? Tempted to swap to some Jones loop bars?frogatthefarriers wrote:Webb H12R
[url=https://flic.kr/p/vcFwGf][/url
Sad, I know,
You Tube:
A copy of the Grit CX Annual hand delivered by the lovely Llyn. An initial flip through looks promising, how much new stuff's there if you're a subscriber, I don't know.
That's got to be the rigid singlespeed of lawnmowersfrogatthefarriers wrote:Webb H12R
Sad, I know,
Lawn needs watering.Ian wrote:That's got to be the rigid singlespeed of lawnmowersfrogatthefarriers wrote:Webb H12R
Sad, I know,
Thanks for the laughs chaps. It's the barebones of lawnmowing.GregMay wrote:Lawn needs watering.Ian wrote:That's got to be the rigid singlespeed of lawnmowersfrogatthefarriers wrote:Webb H12R
Sad, I know,
The lawn does'nt need watering, it needs less fertilizing. Oops!
A crisp packet with a plastic stick inside from Ceulan.
It's going to go nicely with my other thing that I've got to wait AGES for now.
IMG_2574 by flatfishrufus, on Flickr
Today the postie brought a pair of 420mm Exxotic rigid forks and a front disc hub
Plus a couple of days ago I also got a pair 155mm square taper cranks.
Got a neat little build going on currently :)
- TheBrownDog
Not visited this thread for a bit. Stu how long have you been using a long bow? Lovely things. Ive got a Bickerstaffe but don't use it much cos I'm a lazy turd who doesn't understand its true beauty ....Some nocks and nocking pliers for my longbow ... exciting.
My sis took up archery a year ago then this year decided to stick to just the longbow. Winning golds in county competitions already, really pleased for her.
A cracking little afterburner stove and windshield from Stu. Already had a trial run on the patio, and works a treat - cheers Stu!
And some new 165mm cranks for the cx bike, a Thomson seatpost and gear cable for the same.
I have one of those.frogatthefarriers wrote:Thanks for the laughs chaps. It's the barebones of lawnmowing.GregMay wrote:Lawn needs watering.Ian wrote:That's got to be the rigid singlespeed of lawnmowersfrogatthefarriers wrote:Webb H12R
Sad, I know,
Well mine is vintage for extra singlespeed points!
Cumulus quilt 150 after reading all the reviews on here, ordered on Saturday from arklight design delivered today. Great service
Oh and some coffee beans from rave coffee, boring but essential!
https://lh6.googleusercontent.com/-ivDR ... 122806.jpg
A couple of Alpkit tapered air lock bags (one for me, one for the mrs); a set of titanium tarp pegs; a MyTi mug. No shot as I think you all know what they look like
