Real coffee when out on the bike is a weakness for me. And my search for the best cup just got a bit closer Just thought I would share
Normally I use one of these Java Drips, which is good light and efficient. http://gsioutdoors.com/products/pdp/ult ... rip/coffee
OK for 1 small cup, where i use the net bit directly in the cup
Not sure where I heard it but found an old Bodum Coffee Plunger (8 cup one?) in the back of a kitchen cupboard, the diameter of which fits my mug perfectly.
Cut down the handle to suit mug size was the only modification required. and glue the handle back on, what could be simpler!
The extra strong glue was pish so heated the metal rod and melted it into the handle... perfect
The black coffee lid makeds a good mug lid, and the whole thing will screw apart / colapsable for carrying
Real Coffee
Real Coffee
Re: Real Coffee
Ace.
- Farawayvisions
Re: Real Coffee
Stu, can we have a like button?
Re: Real Coffee
I like that .. been eyeing up a similar 4-cup press in the kitchen for donor parts to go with a new smaller ti cup, not sure if dia is right tho. It'd be great if the lid could lift off while the plunger was depressed/in position, so that the cup could still store coffee, mini-stove etc between plunger and lid?
Re: Real Coffee
Plunger will unscrew from the filter end so when travelling you can still store things inside.
Re: Real Coffee
^ That's brilliant then, like it. Unf both the plungers I have are a bit small. My new ti mug now has a bisto tub plastic lid fitted on, a perfect fit. And I'll pinch Ray's excellent coffee tin idea from the other thread for making a decent coffee.
Re: Real Coffee
jameso wrote:^ My new ti mug now has a bisto tub plastic lid fitted on, a perfect fit.
I tried this as a replacement for my myog bottom of whiskey tube lid... perfect fit but melted....
Re: Real Coffee
was intended as a pack lid not an in use lid, defo not tempted to try it now!
