MYOG bar harness
- Charliecres
MYOG bar harness
I used a couple of 6mm (I think) alloy tubes as stiffeners, running in the diagonal pockets on the pad, to stop the load rubbing on the head tube. This works really well.
I did lots of online research and head-scratching before going for this design. It's influenced by the Alpkit harness in particular, although I've never actually seen one in the flesh.
The straps are still too long. I'll trim them once I've used it a bit more with different loads and I'm confident there's no more tweaking required. I may also replace the bar mount straps with velcro, although the existing webbing/buckle arrangement works fine.
Re: MYOG bar harness
Superb job, very pro. I replaced a couple of buckles on the one I made with velcro as I think I used ones that where too small. They clip on one side of the buckle would sometimes pop open and it was also a pain getting them done up tight enough.
- pushbikemike
That looks very impressive. Sounds like it is very adjustable too. What does it weigh?
- Charliecres
314 grams. I reckon it'll be in the high 200s once I've trimmed the excess webbing and swapped the bar straps and buckles for Velcro.
A quick/cheap version;
'Wrap' (very tough but can cut holes with a Stanley, punch etc) from a derelict wheelie suitcase.
Straps from the spares drawer
'keyhole' slits to thread other straps for additional bags. (the molle approach)
Weight 180gm (cut more holes to lighten)
Construction time about an hour
Lasted 2 years so far.
- Charliecres
Neat! Any pics of that fitted? I can't quite picture what goes where and how it attaches to the bars.
- pushbikemike
I had a go at making one.
I copied the well designed and well made harness from Wildcat. Mine is a poor replica and heavier but is effective.
MYOG Bar Harness by pushbikemike, on Flickr
Nice one Mike, any pictures of it loaded?
- pushbikemike
Cheers ray. No pics of it loaded yet. Made it as a spare for anyone joining me on a bivi. Also did a basic one with just straps. Currently working on a frame bag for the full Sus bike and got plans for a new bivi bag after seeing yours.
I've discovered the worst thing about MYOG. You sit down over a cuppa, scribble out a 'clever' idea.... then go to look up materials and see someones beaten you to the punch (looking at you, roy!). Oh well, if ya cant beat em... etc
Mike, your material choice looks interesting, can i ask what it is?
- pushbikemike
Materials came from point north. Cordura 500. A rubberised material on the other side to grip the dry bag. Webbing and buckles. And some yoga mat as padding inside the cordura and rubber material.
Cheers :)
