Sawyer mini water filter - how good?
- Charliecres
I haven't found anything that matches this (on paper) for performance, size and weight at a similar price.
I know various people on here have bought one recently, so does anyone have a real world review?
Re: Sawyer mini water filter - how good?
It's small, light weight and filters fairly quickly. Not sure what else to say really.
- Charliecres
So no problems in use then?
Sounds good
Sounds good
I haven't actually tried mine yet, I got it in November too
Used mine in Scotland and it works as described and is a lot better than the travel tap I had.
Easy to squeeze the water through and the flow rate is ok. Only issue I had was that the plastic pouch/bottle is very stiff and a bit tricky to fill. I'll probably switch it out for something easier to fill, maybe a plastic bottle.
You Tube:
Was about to post the same about the plastic pouch being stiff. Give it a blow to inflate it and it pops into shape. Make sure the gusset at the bottom is expanded and then it stands up.
Do you mean the Sawyer Mini filter?
http://www.trekitt.co.uk/3050/products/ ... tAoddToAgQ
I was looking at a small hand pump for £40 but if the sawyer mini works well that looks better and cheaper..
http://www.tiso.com/shop/eap/accessorie ... er_system/
Review coming shortly ... but there's possibly not much else to say
Well you better not say it's better than the Gravityworks one that I've just bought at twice the price :?
I stand by everything I ever said about the Gravity Works filter ... if there's more than one of you it's superb and it's not bad for non schizophrenics eitherWell you better not say it's better than the Gravityworks one that I've just bought at twice the price
I've got a waterstraw which is a bit lighter but doesn't have an inline function. It's good for slurping out of puddles though!
