Update time, though not much to report apart from a very helpful chat this morning with Andy of
https://armourcustombicycles.com/home
In short, he's happy for me to make use of his jig (and extensive experience) so I'll head along to his workshop early in January to get it all aligned and glued up prior to a short bake in the oven to optimise the curing of the epoxy.
Couple of points:
The design is such that he's not worried about his jig getting messy - it's not a wrap.
Putting the headset cups in early shouldn't be a problem because the bit of the jig that goes against the bottom cup is flat while the top one is conical.
The epoxy is supplied (ET4528) is 'thin-shearing' which means it'll flow nicely where it needs to go before putting the whole arrangement in the jig to fix it in place.
I'll use the qr dropouts for the build phase as they're nice and square and easier to clamp in the jig, and swap them for bolt through later.
All for a bottle of Bunnahabhain
![Smile :smile:](./images/smilies/icon_e_smile.gif)
