Wtd 110 and 148 boost hubs or wheels.
sqibjib
Post by sqibjib »
Morning all
Looking for a set of boost hubs 32 spoke HG hub body, or wheels. Cheaper the better as I am doing a build for a friend, just trying to convince him that sleeping in ditches is a great way to waste a weekend.
Cheers in advance
Stu
Life is better on a bike
Re: Wtd 110 and 148 boost hubs or wheels.
Just about to list some Alpkit ones
650B+ tubeless and 40 mm wide internal IIRC - may or may not be suitable for your needs but will hit the cheap bit
tubeless and will have a set of WTB tyres for it as well if needed [ 2.8" wide though]
My parts bin is not as large as it appears you just seem to want whatever i have :wink:
sqibjib
Post by sqibjib »
Ha ha to funny, your like my own personal second hand CRC.
Let me know how much.
Stu
29er? I have my stock Bontrager wheels from a trek procaliber (2018) that are 29, boost, 24mm wide rim. centre lock disc mounting, shimano HG. A few stone chips and scuffs, one very small ding on the rear wheel I think - but they still ran tubeless fine. They're taped up and with tubeless valves still.
EDIT: ah, i see your sorted, nevermind! If mine are more suitable feel free to PM.
sqibjib
Post by sqibjib »
I think my inbox is not working.
Can you bot text me please 07743336750.
Cheers Stuart
muddymark
Post by muddymark »
Again looks like your possibly sorted here! Just in case you’ve more than 1 friend willing to try sleeping in that ditch…! Have set of velocity wheels 29” rims and hubs, boost spacing, 6 bolt disc lock, 32 spoke and Shimano HG driver, seems to tick boxes so far, although internal rim width little on the narrow side side looks to 23mm ish in the dim cellar light! In very good condition can’t see any marks.
Can do for very reasonable/ cheap price too!
Can post from Sheffield.
sqibjib
Post by sqibjib »
Let me know what's best for you, I can reimburse you for fuel if your passing.
Having trouble with my outbox nothing is sending
Cheers.
Got the message [ you may need to delete some messages though as it they do get full and stop]. will check diary Monday as on holiday and refusing to log into to work to see what i am doing /if i am likely to be passing- will confirm Monday
if not I will post as I have a box
