Line-Loks v Figure 9's for guylines?
I'm just sorting out some new guylines for a tarp and was going to order up some mini line-loks but before I do I'm wondering what the advantages of using 'figure 9's' instead would be?
http://www.ultralightoutdoorgear.co.uk/ ... e_kit.html
All the bumph tells me that if I use figure 9's then I won't have to mess about with knots ... which would be the same if I use line-loks. At the moment the figure 9's just look a little bit more of a faff ... am I missing the point?
Re: Line-Loks v Figure 9's for guylines?
Linelocks look a far neater IMO. Although unlikely, at least when the linelocks are in place they can't come off and get lost.
1.5mm dyneema and linelocks, simples.
Figure 9's look like they handle a greater range of cord diameters, but other than that they look over complicated for what they acheive. I'd rate the mini line lok's as the best solution for finer cord (<3mm diameter).
I can confirm mini line lok's are not entirely reliable with 1.25mm dynemma but are OK with 1.5mm.
I use fig 9's for my tarp ridge line in forested areas, very simple and effective and take only 2-3 seconds to tie around a tree/post etc.. Never had one come loose on me yet.
Can they be used by an idiot? The kind of idiot who'd be safer with slip on shoes thus preventing awkward knot 'moments'.
Actually Flatfish has a very viable reason for them. I camped last night and needed to run a guy around a wire fence, the figure 9's would be a good choice if you tend to use obsticles for attaching guys to.
That said, for tarp duties I dont bother with anything, I just peg it out using a simple overhand loop.
Bowlines are easier to undo after they've been tightened or subjected to a high tension
Good point Ian, I do like a bowline especially for when only one end of the cord is available. The loops were made back when I got the tarp in April so I suspect they will be well and truely knitted now!
I keep contemplating lineloks for the tarp but it has worked fine all year without them so there really doesn't seem much point other than being slightly nicer in use.
i use line loks. small and simple.
I tie a loop on the tarp and a loop on the end of the guy - this means i can seperate the guy if i need to go round a tree/ post.
whilst we're here does anyone know what these 'lineloks' are that MLD use? picture on page 7.
http://www.andyhowell.info/Colin-Ibbots ... review.pdf
http://eu.itwnexus.com/content/lineloc-3-ll
They're like a ladder lock but for cord rather than tape.
Learn to tie a tautline hitch at the peg end of the guy line and a bowline or figure 8 loop at the tarp end. Think of all the weight you can save.
