Now Sorted : Stem cell or similar
javatime
Post by javatime »
Early Alpkit original (black) would be perfect, or else whatever you have have
rudedog
Re: WTD : Stem cell or similar
Post by rudedog »
I've got a couple of these on my bikes, can't really go wrong for £7
https://www.decathlon.co.uk/p/fabric-ha ... 22&c=BLACK
Gpl23
Post by Gpl23 »
https://flic.kr/p/2onU9QT
https://www.flickr.com/photos/193214275 ... 306835879/
ACEPAC fat bottle stem cell bag. Used once
£10 all in
javatime
Post by javatime »
Thanks GPL, but really after black
@rudedog or anyone else - what are the dimensions of the decathlon bag - diameter and total length with sleeve extended?
17 cm length [ soft closure bit is 3 cm, closed it about 16 cm]
circ 9 cm
Mine are about 3- 5 years old though, no idea if they have changed - never had any issue using them
rudedog
Post by rudedog »
just measured mine:
165mm deep including the soft close
90mm wide
Mine are also a few years old and are branded as B'twin, the ones linked are 'riverside'. Apart from the label, they look the same.
javatime
Post by javatime »
Many thanks for measuring both. A bit shorter than Alpkit etc but will be fine for a start. Will order one to tie me over.
Still interested in anything longer and in black if anythas anything
I have two Alpkit stem cells in black, I'm not a fan due to them getting in the way of my knees. Could be persuaded to part with the pair, as I'd rather they went together...
javatime
Post by javatime »
Thanks Boab - have pm'd you
javatime
Post by javatime »
Now Sorted : Many thanks to Boab
