wanted: fat wheels
shutupthepunx
wanted: fat wheels
Post by shutupthepunx »
looking at building up a fattie and id need a set of wheels. 170 rear 135 front. thanks
substandard
Re: wanted: fat wheels
Post by substandard »
Budget?
Front or rear disc spacing on the front wheel?
shutupthepunx
cheaper is better till i get going, and then upgrades can be made. i don't know about which disc spacing.
substandard
What frame and fork are you using?
Early Frames such as on one fatty, surly pugsly etc used rear disc spacing on the front
Front disc spaced 135mm hubs followed later.
shutupthepunx
it's a 9zero7 aluminium frame from 2011, so might that be rear disc spacing on the front wheel? as you may have noticed im a bit lost
Fat tyre kicker
Post by Fat tyre kicker »
Some early 9zero7’s are 135/135 ?
Its might , put a rear wheel in and see
