New bar mount for Garmin Edge with external charge contacts
Asposium
Post by Asposium »
Ever since the Garmin Edge external battery was released thought it would be neat if Garmin released a powered mount with a USB plug.
Well, now they have.
Shame so damn expensive.
Ideal for a BBx straight thru
Or to plug into a dynamo charge converter.
https://www.garmin.com/en-GB/p/784702/pn/BUNDLE-EPM-UAC
lune ranger
Re: New bar mount for Garmin Edge with external charge contacts
Post by lune ranger »
E bike only…
Asposium
Post by Asposium »
lune ranger wrote: Wed Jul 13, 2022 5:57 pm E bike only…
There is a usb cable option.
lune ranger
Sure, but the power needs to come from somewhere.
Generator hub output would need to go through a converter which you may as well plug directly into the unit.
It would save you from getting the USB port in your edge wet though, which can only be a good thing.
I read ir as giving the ability to use a separate (non Garmin) power bank. This would be great if you didn't want to spend £100 on a garmin one, or wanted a larger capacity power bank.
As well as ebike capability....
lune ranger
Suppose so. It’s not a bad idea - it’ll keep your edge safe whilst charging. It’s the the same price as the Garmin battery - I’m very happy with the edge/power pack combo especially with the option to top up from a dynamo.
Think I’ll wait a few years for the solar tech to get cheaper and my current edge to die.
