Hi All,
I'm after a few bits for an easy commuting life. If anyone has any options for the following:
1 - Flat bars, 31.8mm, ideally something with a nice sweep but anything considered.
2 - SRAM Apex 11sp flat bar shifter
3 - Brakes - Some Shimano hydros would be nice for easy bleeding and my existing stock of pads...
Sam
WTD: Bars, Brakes, Shifter (flat bar conversion)
Re: WTD: Bars, Brakes, Shifter (flat bar conversion)
Hi Sam. I have some Manitou Mars I think which you could have for a donation to my mates water-aid charity project. Not sure how much postage would be but can find out for you if interested. Ta...
i have a set of brand spanking new low rise bars and a stem to suit. off a new specialized. any use.
I have some non-series shimano hydros with brand new pads that have hardly been used. Let me know if they are of interest and I’ll dig them out and think of a price
no there is a road one APEX but MTB and ROAD are not cross compatible *I believe any should work with a force mech?
https://www.sram.com/en/sram/models/sl-apx-a1
* 10 speed MTB mechs work with 11 speed road shifters
To make an 11 spd mtb shifter work with force, or rival, you need to fit an mtb cable guide from a mtb mech to get the correct pull ratio. It’s that or buy a sram apex flat bar shifter and use a stock apex, rival, force mech.
I’ve done the opposite 11 speed drop bar levers with eagle mtb mech by fitting an 11 speed road cable guide.
I’ve probably got a mtb cable guide in the garage.
Also got a set of salsa bend flat bars I’ll probably never use.
Thanks for the advice all. I can source an apex shifter I'm sure.
PMs incoming.
PMs incoming.
Sorry Sam... I meant Answer Expert like this one https://www.bicyclestore.com.au/answer- ... rance.htmlredefined_cycles wrote: ↑Thu May 19, 2022 3:01 pm Hi Sam. I have some Manitou Mars I think which you could have for a donation to my mates water-aid charity project. Not sure how much postage would be but can find out for you if interested. Ta...
Name corrected. As above. If you want a Ragley bar instead I also have one of them that's a bit narrower. In grey...
