Locks, for commuting, superlight, strong and reliable...
Is there such a thing as need one to do the long 70 mike commutee but then long the bike at the far end. Usual cheap and sheerful suspects that can be cut open with a strong saw or have their locks seize up, need not apply.
Please thanks kindly. Currently been using zipties but that's where there is higher footfall and parked up really closeby.
belugabob
Re: Locks, for commuting, superlight, strong and reliable...
Post by belugabob »
Ignore the light bit and suck up the weight for the first ride in - then leave it locked to whatever you'd lock your bike to
belugabob wrote: Sat May 14, 2022 4:46 pm Ignore the light bit and suck up the weight for the first ride in - then leave it locked to whatever you'd lock your bike to
Good point, well said/thought. But I already have 2 of them. About 2kg each I'd imagine (maybe more). One is a chain locked up at work with a silver or gold combo lock. Problem is I'm leaving this work place in 2 weeks and will be picking shifts across the region.
Hotels are out the question as I then couldn't afford to come this far and then pay the hotel and train home! :sad: If I took too hefty a lock it then slows me down too much (like by about half an hour maybe or at least it increases the stuff I have to carry, as I'll also have my uniform and shoes :smile:
Pain in the ear question, I know. Booked for Nottingham this Wednesday so might either take zipties or one of my massive locks :sad:
there is no superlight and super secure lock ther eis
light and a deterent
heavy and might work
Given the free availability of battery powered angel grinders does it even matter which you go with? Neither is deterring a determined and well equipped thief
yourguitarhero
Post by yourguitarhero »
I find the folding locks are pretty good for weight/security/ease of carrying and locking up.
Or there are ones you wear as a belt? Might be worth a look
Lazarus wrote: Sat May 14, 2022 5:18 pm there is no superlight and super secure lock ther eis
Hood points John, thanks. Yes, I will be using the lock as part of a ''theft deterrent system' which am hoping will do me the trick :smile: Only question is 'what' as I really think I need more of a deterrant than my current ultra lightweight setup.
Hiplok Gold, wot you wear round your waist...? Will skin you £90 though...
Thanks Bob. Does it get uncomfy wearing it for extended periods (like maybe 5 hours?).
This is the one that's caught my eye for the mo :???:
https://nichollasbrown.wordpress.com/20 ... bike-lock/
redefined_cycles wrote: Sat May 14, 2022 11:22 pm Thanks Bob. Does it get uncomfy wearing it for extended periods (like maybe 5 hours?).
No idea. A colleague has one, but she just commutes across Oxford.
I wonder if it'll be like a hydration pack, annoying to start with, but then you forget about it... 🤷
It weighs the same whether around your waist or on the bike.
I'd suggest that keeping the weight on the bike would be better, as you'd not be lifting it when getting out of the saddle.etc.
psling
Post by psling »
When you're leaving your bike for a longer period of time you can increase security / reduce desirability by spending a couple of extra minutes locking it up. Remove seat post/saddle and take with you, remove front wheel and lock it alongside frame/rear wheel, add a padlock through rear disc (or rear spokes), etc..
That'll help deter thieves looking for a quick snatch & grab.
Maybe look at movement alarms, are there any that link to your 'phone for example.
ps I have a hiplock and don't find it uncomfortable but I haven't done more than about 20 - 30 miles with it and don't ride hard & fast!!
belugabob
Post by belugabob »
This discussion raises the issue of what constitutes good infrastructure, and I feel that secure storage for bikes is often overlooked.
In larger towns and cities, it should be easier, due to the potentially higher demand for such facilities.
Maybe councils could use some of the empty shop buildings for this purpose ?
In other locations - hospitals, universities, office blocks, etc, decent storage should be the norm, rather than trying to cater for more and more cars
belugabob wrote: Sun May 15, 2022 3:18 pm This discussion raises the issue of what constitutes good infrastructure, and I feel that secure storage for bikes is often overlooked.
This is very true and to share some positives. In the 20 years of cycle commuting I am noticing a trend towards better bike storage and parking etc. For example at George Eliot where I did my shift the other day and asked someone parking their bike in the 'lock up cage', for the code. She told me I could obtain it via security. Also at Goole (both non-city so historically haven't ever considered cycle parking as much as, lets say, Leeds) I've managed to locate 'the cage' but sadly it has swipe access only and with me being temporary staff eould find it rather hard/cumbersome getting access.
Hence I need to just find somewehere with good footfall and properly fasten it something with summat solid :-bd
Just gonna use this for Nottingham (75 miles) and see how I get on.
Image managed a pre-made velcro thing I made previously to tidy the actual cable/Kryptonite. Have also found a bike parking map for Nottingham City Hospital so just need to decide which place to park up :smile:
belugabob
Post by belugabob »
Good luck - hope it all works out.
wriggles
Post by wriggles »
redefined_cycles wrote: Sun May 15, 2022 4:24 pm managed a pre-made velcro thing I made previously to tidy the actual cable/Kryptonite. Have also found a bike parking map for Nottingham City Hospital so just need to decide which place to park up :smile:
I wouldnt trust my bike for more than 15 mins with that lock as those cables can be cut with a junior hacksaw in 2 minutes. Personally I would use a small top notch D-Lock to attach the frame to an object every time and take the wieght penalty. Security bolts on stem etc can help as nicking bars and levers seems to be a thing now. As said up thread take the saddle/post off when you lock it.
The other obvious solution is to make the bike less desirable to nick so swap any thing of value off for a cheaper equivalent eg 105 for Claris.
Yep. Your bike only has to be less easy to steal/desirable compared to the one next to it.
wriggles wrote: Mon May 16, 2022 8:45 am
Ta for that info. I never actually knew that it can be slit in 2 mins with a hacksaw. This is my current (other) lock/chain combo I currently use at work. The cuttable cable was meant to be the secondary lock to this chain I suppose...
Two more shifts left for my dilemma to properly kick in :-bd
Interesring little project this is becoming hey. See, commuting never becomes broing :lol: How the heck do you make an IndyFab Crown Jewel less desirable. I have removed the DA cranks and put some Ultegra (PM) ones on already and I suppose there's a touch of rust here and there. Tires and rims are both mismatched :smile: Stem takes ti torx bolts or summat :sad:
I think the fun of riding to work with a Sora might just not be the same :o
A friend of mine wrapped most of his frame in black insulating tape when using it for commuting. Once scuffed up a bit in use it looked quite tatty but the frame was still perfect underneath.
Might have to go back to plan a then and continue researching this or similar https://winstanleysbikes.co.uk/seatyloc ... ck-compact
Closest thing to a D lock apparently and rated to SoldSecureSilver r I think. Plus it can be made compact enough that I could carry it with the rest of my gear (uniform, shoes, commuter clothes etc).
:cry: (not really crying but the icon seemed appropriate).
belugabob
Post by belugabob »
ScotRoutes wrote: Mon May 16, 2022 10:12 am A friend of mine wrapped most of his frame in black insulating tape when using it for commuting. Once scuffed up a bit in use it looked quite tatty but the frame was still perfect underneath.
That's a bit like those leather covers that our American cousins use, to protect the front of their cars from stone chips - maybe adds a bit to the resale value, down the line, but the car looks minging, in the meantime
belugabob wrote: Mon May 16, 2022 12:38 pm
Plus... doubt I'd wanna ride my bike 70ish miles to work after adorning it with ugliness :grin:
At least it might still be there for the ride back though.
The bigger, heavier lock you have, the more attention you bring to the bike and the more you advertise its value.
