Lost and found
Lost and found
So about a year ago I was making my way along a nice trail near me when I collided with a tree, as you do. Some time later I noted my exposure Trace light was AWOL. I went back to the tree and spent ages scrabbling about looking for the light but couldn't find it. I figured it had landed in the (not very well used) trail and someone else had picked it up. I kept looking on subsequent occasions but once all the vegetation had grown up around the area I gave it up as a bad job.
The other day I was passing by, first time in about 8 months as its a dry weather trail only and for some reason thought I'd have a look again. There were old fallen leaves everywhere so this was optimistic. After a few minutes I gave up and went to pick the bike up. There was the light poking out from under a leaf right by where I'd lain the bike down. The wee rubber ring had been gnawed by some rodent and there was condensation in the light lens but after dismantling to dry out lo and behold it took a charge and worked. I then emailed exposure enquiring as to whether they sold the rings separately and they sent me two FOC
Re: Lost and found
I have somehow lost a 2 kg New York D lock in my house and wish i shared your good fortune
Re: Lost and found
I once left my lucky long handled Ti spoon swinging from a branch. A good few months later I was guiding a group and remembered my spoon, a quick mental mapping detour and there it was exactly where I thought I'd left it
Re: Lost and found
Not quite "lost", but I once stashed some beers in a place that I knew I'd be riding past, with friends, about 2 weeks later.
They were still there, when required, and the looks on their faces when I disappeared into the under growth, and emerged with 4 chilled beers, was priceless
Re: Lost and found
Calling Scotroutes.....belugabob wrote: ↑Fri Apr 08, 2022 12:45 pm Not quite "lost", but I once stashed some beers in a place that I knew I'd be riding past, with friends, about 2 weeks later.
I've thought of doing that but the chances of me forgetting where I'd put them would be high....
Re: Lost and found
...only if you'd been sampling them, beforehand...fatbikephil wrote: ↑Fri Apr 08, 2022 2:26 pmCalling Scotroutes.....belugabob wrote: ↑Fri Apr 08, 2022 12:45 pm Not quite "lost", but I once stashed some beers in a place that I knew I'd be riding past, with friends, about 2 weeks later.
Re: Lost and found
Been there, done that! Several times.
WRT 2018, lost my new Exposure Joystick from the handlebars. Finished the ride then checked back in my photos to see if I could tell when it had gone from the bars, then drove to a point where I had been pushing through some undergrowth and on the second or third pass, there it was.
BaM June 2019, my Gallon Bivvy (8 pubs, 8 pints).
Didn’t notice I’d left my (£16) titanium spork where I’d bivvied on the Long Mynd. On the following October BaM, I was passing my bivvy spot so popped into the woods to the tree trunk I’d sat on to eat breakfast and there it was.
And finally, August 2015, canoeing down the Severn with my daughter and her two sons, we stopped for lunch on a sandy bank then paddled on. While we’d been paddling my wedding ring had been rubbing a blister on my finger so I took it off and put it in my pocket. Unbeknown to me, whilst sitting eating, my ring fell out and was left there. My daughter said that when I realised it was gone, eight miles downstream, I was like a dog that had had its collar taken off. You dog owners will know that look.
Anyway, I had a good idea where it might have been lost so two weeks later we paddled back down to look for it, armed with a kids metal detector and St Anthony. When we got to the river, after a few days of rain the level had risen a good three feet and where we had been sitting was under two feet of water.
Nothing ventured - nothing gained, a few minutes later the metal detector beep-beeped and there was my ring under a thin film of mud. Note the 2015 WRT T-shirt.
Thank you St Anthony,
Three-in-a-row for St Anthony.
Re: Lost and found
Good effort Frog!
Sadly my joystick went awol on a commute to work during the 'beast of the east' in 2018 and was never seen again....
- godivatrailrider
Re: Lost and found
Some damn fine beers there.... presumably in my neck of the Woods ( if you'll excuse the cheap pun ) ... I'm in Ludlow..frogatthefarriers wrote: ↑Mon Apr 11, 2022 11:07 am
- UnderTheRadars
- Location: Stourbridge/North Col of North Worcestershire Alps
Re: Lost and found
I do recognise a couple of those barsgodivatrailrider wrote: ↑Mon Apr 11, 2022 1:53 pmSome damn fine beers there.... presumably in my neck of the Woods ( if you'll excuse the cheap pun ) ... I'm in Ludlow..frogatthefarriers wrote: ↑Mon Apr 11, 2022 11:07 am
Re: Lost and found
Similar experience a couple of weeks ago. I'd stopped off and realised my rear light had bounced off of my saddle bag. I slowly rode back up the track I'd just came down, after 20 minutes or so there it was in a tractor rut.
Re: Lost and found
Thanks. I’ve just posted the successes. In the other corner are the many cycling glasses I’ve left behind and a Spot gen2 that I think I must have left on top of the car when I drove off.fatbikephil wrote: ↑Mon Apr 11, 2022 12:57 pm Good effort Frog!
Re: Lost and found
frogatthefarriers wrote: ↑Mon Apr 11, 2022 11:07 am Been there, done that! Several times.
My precious...
- ledburner
Re: Lost and found
I've just found my gas powered soldering iron at the bottom of the wardrobe in the spare room containing the wife's stuff. better still the tank was still half full of butane and I've fixed 3 things with it today.
-dead battery bank, say charging, no output.-loose bat - ve wire.
- sewing machine 'needle' light.
-and an old headtorch alpkit viper or similar.
I'm happy and no landfill
Re: Lost and found
You're very good at this Lu ... I dropped a spacer in the yard yesterday. I've an idea where it is but can't find it. I'll point you in the right direction at the WRT
Re: Lost and found
Don't get me started on that subject - our garden is mostly gravel, and a complete pain, when it comes to bike fettling and dropping small boltsBearbonesnorm wrote: ↑Wed Apr 13, 2022 8:17 am You're very good at this Lu ... I dropped a spacer in the yard yesterday. I've an idea where it is but can't find it. I'll point you in the right direction at the WRT
Re: Lost and found
You could always try St Anthony.Bearbonesnorm wrote: ↑Wed Apr 13, 2022 8:17 am You're very good at this Lu ... I dropped a spacer in the yard yesterday. I've an idea where it is but can't find it. I'll point you in the right direction at the WRT
- ledburner
Re: Lost and found
check out the nearest crows or magpies nestfrogatthefarriers wrote: ↑Wed Apr 13, 2022 8:33 pmYou could always try St Anthony.Bearbonesnorm wrote: ↑Wed Apr 13, 2022 8:17 am You're very good at this Lu ... I dropped a spacer in the yard yesterday. I've an idea where it is but can't find it. I'll point you in the right direction at the WRT
...or divining rod.. ouji board....
or put an old sheet down first....
wood strips for boundaries....
