FS: reasonably light camping chair
TheBrownDog
Post by TheBrownDog »
This is an ALITE Mayflower I've had for quite some time, but not used since splurging on a Helinox chair about three years ago. It weighs 725g, so not what you'd call ultralight, and packs down to the size of a 1l bottle of fizzy beverage. It's low to the ground, so the underside is a little grubby, but otherwise in very good condition. It's very comfortable and has a weight limit of 115kg. It's party trick is that you can use it without the front strut, so it becomes a little rocking chair that you balance on the base feet, which was how I used it most. £25 posted.
polarcherry
Re: FS: reasonably light camping chair
Post by polarcherry »
£20 posted? :cool:
TheBrownDog
polarcherry wrote: Fri Sep 03, 2021 9:15 pm £20 posted? :cool:
Oh, go on then. Will PM ya. Thanks
