Garmin mount for 22mm bar
Charliecres
Post by Charliecres »
I want to try mounting my Edge Explore on the front loop of my loop bars and also on one of those extender bar thingummies. I can find mounts for TT bars but obviously they all mount the Garmin at 90 degrees to where I’d need it.
I suppose I could try packing out a 31.8 mount but I’d prefer something more solid.
Can anyone recommend a mount, or a clever solution?
Ta.
psling
Re: Garmin mount for 22mm bar
Post by psling »
I've used two part 22.2mm bmx handlebar shims which take you up to 25.4mm and then reducers are generally available 31.8 - 25.4mm if needed.
Wotsits
Post by Wotsits »
You can get spacers from 22 to 31.8, i've got my Maxx-D mounted like this (sorry, can't find the ebay linky).
A thin piece of heli-tape on the bar should help to prevent it from slipping.
Edit: Think it could be one of these-
https://www.ebay.co.uk/itm/282823719164 ... SwItFen8vk
One of these would allow you to use one of the many 1/4mounts. Should have one spare, can post you one of whatever I’ve got for you to try if you want Charlie.
Chicken Legs
Post by Chicken Legs »
https://www.wiggle.co.uk/exposure-254mm ... lsrc=aw.ds
I think this is what you want.
You can modify the exposure quick release mount to take a Garmin Mount and with this shim its good to go.
Just found this which is what I was trying to describe.
https://road.cc/content/news/92312-expo ... t-eurobike
Charliecres
Thanks all. I’m going to go with the shim Suggested by Wotsits. (Thanks very much for the kind offer to post one, Wotsits, but I might as well get a spare or two so I’ll go with eBay.)
