Wet Gear Query
Wet Gear Query
Whats everyone's go to wet gear for when the weather is unrelenting, breathable ish jackets pants etc ? The good the bad & the recommended, let's hear em
Re: Wet Gear Query
Columbia Outdry jacket is still my favourite when it's pissing.
Other items I'm less successful with.
Waterproof trousers never seem to last long before they're letting in at the arse.
Sealskinz gloves have worked well but the most waterproof are very cumbersome.
I'll double up waterproof boots AND socks when it's bad but for multi-day trips I still like my Goretex socks. They dry quite quickly - usually overnight
- ledburner
Re: Wet Gear Query
Take up a new past time?
Rain poggies (uninsulated) for keeping hands & gloves drier.
helmet cover.
gaiters./over boots, cropped over trousers & braces.(suspenders sounds kinky, is it me? )
Good guards & flap to minimise wearing stuff off wheels.
Follow reproofing & garment care blurb.
I've never been impressed with rain shedding or gament durability..
( Read before purchase if possible.. )
helmet cover.
- ledburner
Re: Wet Gear Query
rain poggies (uninsulated) for keeping hands & gloves drier.
helmet cover.
Follow reproofing & garement care instruction.
(:ugeek: Read before purchase if possible.. )
helmet cover.
Re: Wet Gear Query
columbia outdry jacket. it is the best waterproof i have ever owned for cycling.
Re: Wet Gear Query
Is there a model of the Columbia outdry jacket I'm not seeing as the ones I can see look pretty short in the body and definitely in the backside department? Not a problem?
Re: Wet Gear Query
Outdry here too.
They're not a cycling cut, unfortunately, but I can live with it as do others.
Go for a model with pit zips if you fear overheating and are a sweaty beast. The breathability "flaw" of the fabrics is more than made up for by its durability and not needing to maintain a DWR.
I seem to kill any DWR in short order and find reproofing treatments very hit&miss.
- thenorthwind
Re: Wet Gear Query
What Colin and Ton said. The only jacket I've ever had that I know I'll stay dry inside whatever gets chucked at it.
Agree, they're not perfect, but the actual waterproof-ness far outweighs any minor design issues.Cheeky Monkey wrote: ↑Wed May 05, 2021 8:15 am They're not a cycling cut, unfortunately, but I can live with it as do others.
Re: Wet Gear Query
Should we start a campaign to force them to make us one that covers our bums?
- Charliecres
Re: Wet Gear Query
+1 for Outdry
- Bearlegged
Re: Wet Gear Query
Outdry in cooler weather, Shakedry when it's warmer.
I've given up on DWR coated fabrics.
Re: Wet Gear Query
best thing about outdry is that the xxxl size is a proper xxxl size.
Re: Wet Gear Query
outdry jacket
Endura Stealth trousrs [ no longer available but 100% waterproof but arse
Waterproof boots [45 North Wolfhammer ]
Waterproof socks
Aldi gloves or neoprene if not supercold or pogies if proper winter
Waterproof socks
Re: Wet Gear Query
Just wondered what everyone was using as I'm sat here watching the rain & hail bounce off the windows, just got me thinking
Tbh I only ride in the rain if its needed, I don't tend to say right it's lashing down I'm off for a spin. Some big shouts for the outdry jacket, thought there would be more for Gore but hey that's why I asked first
Cheers chaps
Cheers chaps
Re: Wet Gear Query
I'd just like to say - outdry too. Such a shame that they seem increasingly difficult to find.
Re: Wet Gear Query
OMM kamelika (or something like that!) smock works well for me. It's my old fell running one, and is starting to fall apart after 10 years. Not quite as storm proof as my heavy duty Patagonia jacket, but stretchy, breathable and noticeably warmer on cold wet days than its super light replacement.
Aldi waterproof cycle trousers and gloves are great, double waterproof fabric in the saddle area seems to last well. Current pair are at least 5 years, including 18 hours at strathpuffer, old and still waterproof.
Re: Wet Gear Query
I find 400g to be the sweet spot for proper waterproofing (but might just be me)... Got this after getting bored of my Lowe Alpine and it startong to get cuts (after many many years... not to be confused with many many many years).
https://www.trekitt.co.uk/clothing/jack ... nge__36187
Been really happy with it and mine in L weighs about 395g
Re: Wet Gear Query
Noted. That means I could buy another Essence and wear it on top of and at the same time as my existing one, and be exactly on the sweet spot. Then I'll be doubly (*) dryredefined_cycles wrote: ↑Wed May 05, 2021 12:16 pm 400g to be the sweet spot for proper waterproofing
(*) I mistyped that as "dobly" - Nigel Tufnell strikes again!
Re: Wet Gear Query
Whereas I will enter with my stuck record line to say that the only top that has ever worked for me is a Paramo Vélez Lite. Yes I do run hot too and it can get hot in very warm summer rain, but usually it’s fine and copes with being patched really well.
I can ride for 12 hours in it and climb into the tent and wear it while cooking tea. I will be dry inside anyway and after an hour it dries out all through.
I wear waterproof shorts down below. Never use long waterproof trousers on a bike.
Re: Wet Gear Query
Just to check, will you be dry underneath it in prolonged heavy rain? I'm coming round to the idea that I could justify carrying a heavier waterproof if it
1) keeps me dry
2) stops me ending up on the verge of hypothermia, and
3) continues to do 1 and 2 rather than just for the first few months I own it.
I also like the idea it can be repaired if I tear it.
Re: Wet Gear Query
Shaf, do you mean a jacket weighing 400g? Does weight perhaps depend on the size of said jacket, how many zips, toggles it has and whether you remembered to empty the pockets properly before weighing it?
Re: Wet Gear Query
Sorry... yes, 400g in a medium to large with empty, just the jacket. The lightweight stuff (Columbus not applicable cos it never fit me properly when trying it on) just wasn't cut up to protecting from the elements properly.Bearbonesnorm wrote: ↑Wed May 05, 2021 6:15 pm Shaf, do you mean a jacket weighing 400g? Does weight perhaps depend on the size of said jacket, how many zips, toggles it has and whether you remembered to empty the pockets properly before weighing it?
I've also gone/decided on similar criteria for the trousers (I get cold quickly... and wet) which came recommended by the shop (BACS). Mountain Equip again and turned out they too were 400ish grams. The Lowe Alpine which worled well for me, again, 400g. Anything that I've tried in lighter fabrics just ends up being cold and shivery.
Wierd... I know
Re: Wet Gear Query
Another Paramo fan here - Quito in Spring, Summer and Autumn, velez light in Winter. Heavy but in most cases up here when it starts raining it gets very cold and its really nice to jam it on, feel warm and know it will keep out all know rain. To echo Hamish, you can put it on over wet gear and you will dry out underneath it. A bit sweaty when its warm and raining but this doesn't happen much in Scotland. Bomproof too and repairable.
If I know its not going too rain much and its warm, I'm using either a Gore c3 goretex active on the road bike or a Keela Saxon for off road. The latter leaks with heavy rain but OK for drizzle.
For bottoms I use Paramo velez trousers in the winter but these are too warm for Spring and Summer. Rab downpour (pertex shield) if its not going to be too bad, Berghaus goretex active trousers if its proper wet. These have been good so far but as Colin says bottoms never last long on a bike - they either go at the backside, crotch or ankles. I hate wet feet so go for goretex boots, waterproof socks and gaiters if its horrible.
Re: Wet Gear Query
Yes. I put it on ride, and at the end I’m dry. You can sweat in it of course and maybe get drops down the neck and up the sleeves, but for that all day riding in the rain situation it keeps me dry.sean_iow wrote: ↑Wed May 05, 2021 6:06 pmJust to check, will you be dry underneath it in prolonged heavy rain? I'm coming round to the idea that I could justify carrying a heavier waterproof if it
1) keeps me dry
There are a few caveats... it works best with good wicking thermals. Merino will work but I don’t think it wicks fast enough to be optimum. I now use Paramo grid thermals unless it’s very warm. Also, You do have to wash and retreat the jacket from time to time. I don’t do it as often as I used to - and it still works. It’s easy to do; I wash mine by hand in a bucket and it takes no time... but a takes a while to dry.
I prefer the lightweight Vélez and my oldest one is covered in stick on patches. It still works.
