Super Boost.
Re: Super Boost.
Some technical explanation from Surly here: https://surlybikes.com/bikes/krampus, though I'm gnot sure my maths is up to it
Re: Super Boost.
Is Super Boost rear paving the way for 14 and 15 speed? Need to get those wider rear ends established.
Re: Super Boost.
I forgot to add that the 36t ring is spaced to a Rohloff chain line. I thought boots chainline was pretty similar though.Alpinum wrote: ↑Mon Apr 26, 2021 9:44 pm
The newer Krampus' with (gnot) boost seem to fit max 34t (which is what I'm running on mine, MY2017, and it's already tight), have a simpler yoke (surely quite a bit cheaper to make) and the boost front still asks for some tyre wiggling.
No idea if the chain stay became shorter though.
The picture shows an oval 36t ring at it widest point and lots of room to spare.
https://share.icloud.com/photos/0nou2KI ... d_Hospital
Re: Super Boost.
Oh... no idea, but good point. I don't even know if my chain ring is 6 or 3 mm (boost) offset. think it's 6 mm, since I took it over from a non boost frame. I ride ssp on my Krampus, so I just make sure to get a straight line.lune ranger wrote: ↑Tue Apr 27, 2021 7:43 amI forgot to add that the 36t ring is spaced to a Rohloff chain line. I thought boots chainline was pretty similar though.Alpinum wrote: ↑Mon Apr 26, 2021 9:44 pm
But of course, putting the chain line slightly outwards would give option to a larger front ring (and thus a larger rear cog for the equivalent gear when ssp'ing, which helps in two ways).
Re: Super Boost.
Harder to give carbon frames those thin, 'plates' chain stays though I guess?
Re: Super Boost.
IIRC it was the VF 400 that had inboard discs.Bearbonesnorm wrote: ↑Tue Apr 27, 2021 6:30 am
Ooh cbx 550 Steve? One of my all time most despised bikes
Edit: no, can't be, you said v4, although I can't think which. Did the 500 have inboard discs?
I had a CBX550, Honda said the inboard discs were so that they could use cast iron rotors for better wet weather braking but the brakes were crap anyway and when you took them to bits to change pads everything was a rusty mess inside (like car brakes). It was when Honda went through their "we do everything differently cos we're so clever" phase but they weren't clever enough to make a functioning cam chain tensioner! At least it didn't have 16" wheels though.
Re: Super Boost.
I think a few Hondas did - 550 and the first VF's (although that was the least of their problems according to my Honda dealer employed mate....) I think the later cx 650's did for a bit as well.
- BigdummySteve
Re: Super Boost.
VF400, thankfully one of the problem free V4,s gear driven cams....Was a pain to service however, setting valve clearances involved, removing tank, air box, coils and tray,radiator and draining coolant then removing a section of the frame then it was possible to remove the valve covers and then you had 16 tiny valves buried deep within. Took most of a day.
Love a V4 though, the VF 750 (pre-vtech) is in my opinion one of the nicest bike engines ever, that sound when you ‘accidentally’ enter a corner a gear too high and use the midrange grunt to pull it out...sublime.
Edit: yes it had a 16” front wheel, tyre choice was Avon roadrunner, I actually got used to the front drifting.
Re: Super Boost.
I owned a rat VFR 750 for a bit (first single sided swing arm one) and it did indeed have a lovely engine. The bodywork was horrible as it consisted of multiple bits and mine had been down the road on both sides which didn't help. I contemplated removing it all but its a plumbers mess underneath the plastic. Sold it a mate who still runs it round Edinburgh as his hack.BigdummySteve wrote: ↑Tue Apr 27, 2021 8:20 pm VF400, thankfully one of the problem free V4,s gear driven cams....Was a pain to service however, setting valve clearances involved, removing tank, air box, coils and tray, draining coolant then removing a section of the frame then it was possible to remove the valve covers and then you had 16 tiny valves buried deep within. Took most of a day.
Re: Super Boost.
my Salsa Spearfish is Superboost
it’s a far better bike than i am rider
(and please no cheeky comments of ..... That wouldn’t be hard )
