Post to flatmount adapters
Gari
Post by Gari »
Has anyone got first hand experience of these adapters? I’m looking at some Force brifters, the are post mount while the frame is flat mount. They’re a bargain, but only if the will work well!
Thanks in advance!
In Reverse
Re: Post to flatmount adapters
Post by In Reverse »
I've used one on the rear for several years on an old hardtail. Can't imagine you'd have any issues with either tbh.
Gari
Post by Gari »
Thanks in reverse. Bargain ahoy then👍😁
In Reverse
How much are the brifters?
Been using TRP ones on my Camino for the past year or so, all good and trouble free :-bd
Gari
Post by Gari »
£300
I thought you could not do post to flat - ie if the caliper is POST it wont go on a flat frame- there is no adapter for this
You can do a flat mount calipe ron to a post mount frame with an adapter
As in reverse has an old hardtail i assume its post mount FRAME and flat caliper
Google seems to agree with this assesment but i have no real world experience of this
Gari
Post by Gari »
So I can and I can’t!!
Schrodingers brake mount adapter then🙄
That said, I’m pretty sure I read it’s the opposite to what I now can’t do!!
Lazarus wrote: Wed Apr 07, 2021 1:05 pm I thought you could not do post to flat - ie if the caliper is POST it wont go on a flat frame
So did I so I googled it
https://www.merlincycles.com/trp-flat-m ... source=PHG
Post caliper to flat mount frame adapters.
In Reverse
Lazarus is right, sorry Gari. Just looked back through some old photos and that's confirmed I was talking through a hole in my hat.
edit - this thread is a real voyage of discovery now...
Gari
Post by Gari »
https://www.bikehugger.com/posts/road-d ... ost-mount/
https://www.merlincycles.com/trp-flat-m ... 89957.html
Seems it can be done either way then:)
Rear might be an issue on a small frame52)
I might send Mason an email to check!!
In Reverse wrote: Wed Apr 07, 2021 1:28 pm edit - this thread is a real voyage of discovery now...
I looked into it years ago when flat mount frames were a new thing and it wasn't possible. The adapter manufactures seem to have caught up now, which is good.
They say you learn one new thing a day... I wasted today's new thing on adapters for a frame I don't own :lol:
Gari
Post by Gari »
😂😂😂 glad to be of service!!
Thems the trp ones I've been using with post mount calipers and flat mount frame... :grin:
Edit: should clear fine still, and I guess you could use a 140mm rotor if you needed to for a smaller adapter
